Joined the site to post a couple of answers.
Have had the device for about a week.
Tried wireless trendnet n usb as it is a recommended wireless usb stick. Network drops after a few minutes. Streaming from a Windows Home Server.
Changed to the Linksys 610. Had the same problems as the guy above. Solution to that one, by the way, is to look in the settings for place that lists "workgroup" and change it to your workgroup name. Mine had been changed. In that section there is also a place to add a user. One of those two things allows you to see past the router. Took the router back when I realized it wasn't the problem and went back to my dlink 655.
The story gets better.
Picked up a wireless dlink 1522 bridge/AP. Bridged the 1522 to my dl655 and then hardwired the WDTV to the bridge.
Disconnect after a few minutes playing a file off network share.
Gets better.
Bought and returned dlink powerline adapters.
Same problem.
Figured that I needed a true hardwire to my switch two floors away so I get out my drill and properly wire a cat 5e cable between the WDTV and my switch.
Guess what?
Same f'ing problem.
So tonight, I went and found my receipt to return the device and I thought to try what someone stated above....turn off the setting for sharing the WDTV on the network.
Problem gone so far.
Played 3 shows so far and no problem.
Think that when the WDTV is shared it broadcasts a default "workgroup" that conflicts with your network if you are running a non standard name, as I was.
Maybe my solution would have been to change my workgroup name to "workgroup"? Won't know as it is working great now and I won't be messing with anything.
Thank god the bridge could be switched to an AP as I beefed up my wireless in the basement with it.
Gets better.
Same problem.
Guess what?
Same f'ing problem.
