Originally Posted by yushi
Hi
I want to buy this media player.
Could you please tell me how this BT works in the device?
Does the media player should be connected to a computer in order to download?
can I connect my DSL modem to it?
it's just that i have a laptop which i take with myself so the BT doesn't make sense if it should be connected to a computer.
thanks
Hi
thanks
BT: you will have to install a HDD into the unit and format with the PBO. Once access PBO via IE or any web browser, you can start adding BT seeds into the unit via web UI. Once start, PBO will download the file for you. Media player only needs to be on the network (wired or wireless network), no need to direct connect to PC.
DSL modem: i assume you meant having the PBO connect directly to the DSL modem? Yes you can. I assume your DSL modem also serve as a router?
