Originally Posted by aviator79
My wireless box seems to be going out. Worked fine for over a year but now I am getting a red blinking red power light. Previously I was able to press it to make it turn green and it will connect, but not this morning. My wife said this happened to her the other day, but when I came home from work I was able to get it to connect. I have other problems with the set as well. DSE appeared recently. I did not have it when I first got the set which is really weird. I have had the Trumotion bug from the beginning and I am not sure how to fix that. My other issue seems to be with my directTV as sometimes the bottom 1/3 of the screen will get all glitchy and jittery when things are moving around. I'm not sure if this is my direct TV or a bad HDMI cable or the wireless or what. But Blu-rays I never have a problem so...who knows.
Anyways, I just got a Kinect and had to buy a 15' extension to reach the corner of the room where everything is located, so I figure a 25' HDMI cable should reach but it will be close. I believe this is what some of you are doing. Any help would be appreciated. Should I call LG? Will they fix the trumotion bug for me for free? Would love it if they would fix the panel and the wireless too...
I think the bulk of the members, have put the Media Box to the side, and are directly connecting from the AVR, or some of us are using the iScan Duo. I assume you have tried the direct approach off your AVR?
. The MSRP was around 5,000 wasn't it?
