Network Solution Needed
post #1 of 3
Hi All!
I have trying to stream my Hd movie through my media server,but i no luck
Bought the belkin powerline HD (1000mbps) supposely.
Bought the Belkin Gigabit N+ Wireless Router.
The problem i cant stream 1080p files if the powerline adapter are not far from each other,but when the distance became a little bit longer it seems to lagging.
i live on a two story house and my mediaplayer is downstair and router is upstair.
I am running out of ideas and getting faustrated.
If anybody can help find a product that works,i'll be well pleased.
Ps:I have looking into a Gigabit wireless N router + Gigabit Access point.
Tell what your think.
post #2 of 3
Originally Posted by dmoney94 View Post
Hi All!
I honestly have never had luck with powerline as there are a lot of factors that determine the throughput that you get. I ended up just running Cat6 and now have no issues streaming.
Another solution (I have not tried but have read other people having success) would be to try a Coax solution instead of powerline, still al little expensive though:
http://www.newegg.com/Product/Produc...22243&Tpk=MoCA
post #3 of 3
I will take a look into that.
Thank you!
