Howdy all!
Moved into a new house - excuse for new speakers!!
I have been using homebrew monsters. They have a big sound, go plenty loud, fairly smooth, easy to listen too. Big ugly black boxes though.
This system will see 50/50 HT and music. We're not extreme volume freaks but like to be able to turn it up some.
The room is HUGE: 6000+ cu ft.
The system will surround a 10ft (diagonal) projected image. A big, effortless sound is necessary. Same time, I don't want huge floorstanders.
Budget is around $1000 for the set of 5: fronts, center, surround. No 7.1 for me. Bass will be the topic of another discussion.
I ordered a pair of each of the below:
Magnepan MMGW. Have Maggies as the streo music system now, they are seductive... i have high hopes for these...
HSU HB-1
http://www.hsuresearch.com/products/hb-1.html
tSc TSB 5.25
http://www.thespeakercompany.com/TSB...air-P45C6.aspx
tSc LCR3-P (these are DIRT cheap, and all tSc speakers are 20% off now)
http://www.thespeakercompany.com/LCR...ers-P41C6.aspx
EMP Tek e5bi
http://www.emptek.com/e5bi.php
Any comments/suggestions? Any other speakers I've missed should give a try?
I plan to set up them all up and do head to head comparisons vs. my existing homebrew and each other. Whatever sounds the best stays. I may end up just rebuilding the homebrews in smaller prettier cabinets if that's what it takes.
Gratuitous pic of the homebrews attached. That's four 4 mids and one 30mm tweet per box. Parts from MCM a few years back. Sorry image is dark. Yes tweeter got damaged, have replacement in a box.
HSU HB-1
tSc TSB 5.25
EMP Tek e5bi
