AVS › AVS Forum › Audio › Speakers › Recommendations for 2.1 speakers, budget $500
post #1 of 6
These will be for a small-ish living room and later on a bedroom. I'll be listening to a lot of music (pop, rock, hiphop, country, very occasionally classical) from the laptop and it'll be hooked up to the flatscreen for movies. Should I get a receiver? Is the amp necessary? Budget is around $500 but I'm flexible on that especially on the lower end . Thanks!!
post #2 of 6
if you ever plan to upgrade to 5.1 or 7.1 in the future, you should invest in a receiver
as for speakers.. there's a lot of good ones in the <$500 range
post #3 of 6
unless the speakers have built in amps (i.e. "active" speakers) then you will need to provide some form of amplification.
I would grab an inexpensive used receiver off craigslist, and then get a sub and a nice pair of bookshelf speakers. Any requirements in terms of size (e.g. tower vs bookshelf vs small satellite) or aesthetics (black vs wood color) etc?
post #4 of 6
any size could work and while I prefer lighter colors and wood (like birch) over black, aesthetics don't matter that much.
are these any good?
http://chicago.craigslist.org/nch/ele/1427271534.html
http://chicago.craigslist.org/nch/ele/1428005202.html
post #5 of 6
Those Energy Minis don't look bad but I think you can do better than that pioneer receiver. You can find pretty good receivers on craigslist for around $100, just keep looking. I live around Chicago too, and I look at the Craigslist electronics section every few days for the northwest suburbs to see if there are any steals, and I usually see some great deals for receivers and amps. Subwoofers can eat up a lot of your budget fast, so what you might consider is getting full range speakers for now, with the option of getting a sub later if you decide the bass isn't enough for you.
Here are some options for full range speakers which I think look good in your price range:
BIC Acoustech PL-76
BIC Acoustech PL-89
Infinity Primus p362
EMP Impression E5ti towers
Elemental Designs A6-6T6 tower speakers
TSC TST2 towers
There are some good speaker/sub combos that might fall on your budget though. Some subs you should check out are the BIC Acoustech H100 and the Hsu Research STF1 (there's a pretty good sale on that one right now). Some decent and inexpensive bookshelf speakers which could go well with those are the Hsu HB-1s, The SVS SBS speakers, the Tweakcity WAFs, the TSC TSBL 6.5s, and the Infinity Primus P162.
post #6 of 6
Those speakers in the 2nd link were Energy RC-10's not RC minis so that was a pretty good deal!
You should check out a place called Saturday Audio which is in Chicago. They have deals on PSB speakers which you can get in light colors like maple.
http://saturdayaudio.com/
http://saturdayaudio.com/picturepage...9-2009.htm#B15
You should be able to get 2 bookshelf speakers there for $300 and then find a decent receiver or craigslist for cheap.
  Back to Forum: Speakers
