Danley supplies a list of the parts included in the kit and recommended parts including quantities that are not provided. Some of the stuff you would need to get are:Screws for the panel assembly. Drywall/wood or whatever. Just get a whole box. You need probably 200 or more. 10-24 machine screws for the hatches. Driver mounting bolts (These were listed as 1/4-20 in the list but that is not right BTW). Screws for mounting the grill. Cable ties. A large bottle of wood glue, or something like PL premium. Some sort of silicone or other sealant (you need this for where the wires go through the driver baffle at least.) A few feet of speaker wire. Whatever connector/s you wish to use. Beer.
As far as tools, you don't need much. I used : A power drill, a set of assorted phillips bits, a set of drill bits (a few of the panels were not pre drilled, no biggie, plus you'll need it for the grill and the connector panel.) A spade bit for the speakon terminal. A flat head and phillips head screwdriver. A set of allen wrenches (I used a little $10 allen ratchet to great effect because all of the driver and hatch screws I used are allen hex.) Wire stripper. Exacto knife. A towel or rag to wipe off excess glue and sealer. A bottle opener for the beer. That's about it really.
Originally Posted by Ivan Beaver
Not everybody wants the same kind of connectors-so there is just a recessed area for you to put whatever connector you want in it.
Some people will drive it off of a single channel and others (like Ricci) will drive it off of 2 channels-so the flexability of connectors is left to the end user.
Right. I think it's about a 4"x4" recessed area for the connectors. Plenty of room for whatever. Interestingly on the inside of the side panel by the outer drive unit there's a recess. I guess that's another possible spot.
. Usually the extreme efficiency is what is touted. Really it's 2 different ways to skin a cat both allowing the driver to put out more sound with less effort (displacement).
