Originally Posted by Ivan Beaver
If I was going to spend that kind of money-and time, I would want to be SURE that what I did was worthwhile-or not before I recommend it to somebody else (unless you just trying to sell the cabinets then
About the only way to do that would be to take accurate-calibrated measurements in the exact same place-with the same drive levels noted-(baseline and max) before and after. Then compare them.
If you don't-then it is PURELY subjective-since there will be a good time interval between listening to one then the other. And of COURSE you want it to sound better-so you would naturally think that.
Measurements are about the only way to take the "subjective" out of the equation.
But they have to be done RIGHT-or it is pretty much worthless.
.About the only way to do that would be to take accurate-calibrated measurements in the exact same place-with the same drive levels noted-(baseline and max) before and after. Then compare them.
Ivan is a BC 412 OR THE TH412 good for home theater?
but If I did put it in the room somewhere, especially on the floor, I fear complaints
) but only about 45" wide, and to make one fit would mean removing skirting board, removing plug sockets and aerial sockets and moving them further along the wall, finding somewhere for the separate amp, placating the missus... lol
