i am mounting a 60 pound 42 inch plasma on 2 2*4 studs with 3.5 inch long 5/16's and predrilled holes of 3/16 diameter which are 3.25 inches deep (0.25 would be used up by the frame and washer). i have proceeded gingerly with a socket wrench and am currently at this stage :
0.75 outside (ie the shank)
0.75 in drywall
2 in the stud
here comes the newbie part:-). the socket wrench is pretty hard to turn and i fear the bolts might snap if i continue. i am minimising sideways movement by applying pressure on the socket wrench head while turning in small increments of 20 degrees.
if i use some spacer for the 0.75 on the outside, would it provide adequate strength for my 90 pound = 60 pound tv + 30 pound frame load.
or i should just continue tightening the bolt? slowly!
0.75 in drywall
2 in the stud
