Blu-ray File size: 47.70 GB
Bitrate: 31.29 mbps
Code:
Total Video
Title Codec Length Movie Size Disc Size Bitrate Bitrate Main
Audio Track Secondary Audio Track
00003.MPLS AVC 2:29:53 44,644,798,464 45,008,217,238 39.72 31.29 DTS-
HD Master 5.1 4658Kbps (48kHz/24-bit)
Code:
DISC INFO:
Disc Title: TRANSFORMERS_2_D1_AC
Disc Size: 45,008,217,238 bytes
Protection: AACS
BD-Java: Yes
BDInfo: 0.5.3
PLAYLIST REPORT:
Length: 2:29:53 (h:m:s)
Total Bitrate: 39.72 Mbps
VIDEO:
Codec Bitrate Description
MPEG-4 AVC Video 31290 kbps 1080p / 23.976 fps / 16:9 / High Profile 4.1
AUDIO:
Codec Language Bitrate Description
DTS-HD Master Audio English 4658 kbps 5.1 / 48 kHz / 4658 kbps / 24-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps
/ 24-bit)
Dolby Digital Audio French 640 kbps 5.1 / 48 kHz / 640 kbps / DN -4dB
Dolby Digital Audio Spanish 640 kbps 5.1 / 48 kHz / 640 kbps / DN -4dB
Dolby Digital Audio English 224 kbps 2.0 / 48 kHz / 224 kbps / DN -4dB
SUBTITLES:
Presentation Graphics English 41.365 kbps
Presentation Graphics English 44.305 kbps
Presentation Graphics French 38.795 kbps
Presentation Graphics French 0.353 kbps
Presentation Graphics Portuguese 33.963 kbps
Presentation Graphics Spanish 33.815 kbps
Presentation Graphics Spanish 0.330 kbps
FILES:
Name Time In Length Size Total Bitrate
00003.M2TS 0:00:00.000 2:29:53.025 44,644,798,464 39,715
CHAPTERS:
Number Time In Length Avg Video Rate Max 1-Sec Rate Max 1-Sec Time Max 5-Sec Rate Max 5-Sec Time Max
10Sec Rate Max 10Sec Time Avg Frame Size Max Frame Size Max Frame Time
1 0:00:00.000 0:08:49.278 32,961 kbps 42,213 kbps 00:01:27.587 36,152 kbps 00:06:15.917
35,880 kbps 00:01:44.729 171,830 bytes 808,861 bytes 00:01:02.771
2 0:08:49.278 0:06:03.363 31,962 kbps 39,439 kbps 00:13:10.372 35,990 kbps 00:12:40.468
35,830 kbps 00:12:40.050 166,635 bytes 440,567 bytes 00:14:44.842
3 0:14:52.641 0:03:25.371 30,812 kbps 36,824 kbps 00:17:45.731 35,619 kbps 00:17:36.054
35,009 kbps 00:14:56.979 160,640 bytes 336,771 bytes 00:17:25.002
4 0:18:18.013 0:06:49.617 31,348 kbps 40,106 kbps 00:23:59.229 36,244 kbps 00:20:48.455
35,772 kbps 00:19:50.814 163,433 bytes 421,308 bytes 00:24:13.869
5 0:25:07.631 0:07:52.889 31,811 kbps 37,859 kbps 00:32:43.836 35,951 kbps 00:25:18.141
35,890 kbps 00:25:13.261 165,846 bytes 427,487 bytes 00:29:57.378
6 0:33:00.520 0:04:07.247 31,527 kbps 36,739 kbps 00:33:45.106 35,961 kbps 00:35:30.336
35,400 kbps 00:35:14.779 164,365 bytes 292,544 bytes 00:33:50.653
7 0:37:07.767 0:06:25.885 31,636 kbps 37,319 kbps 00:37:45.680 36,106 kbps 00:37:19.445
35,944 kbps 00:37:35.753 164,935 bytes 388,314 bytes 00:37:49.642
8 0:43:33.652 0:11:22.890 31,711 kbps 38,676 kbps 00:53:13.231 36,254 kbps 00:53:09.102
35,832 kbps 00:46:34.541 165,328 bytes 375,896 bytes 00:54:00.987
9 0:54:56.543 0:08:27.340 31,426 kbps 39,879 kbps 00:59:57.927 36,116 kbps 00:59:30.066
35,786 kbps 00:58:33.635 163,841 bytes 437,252 bytes 01:02:09.142
10 1:03:23.883 0:09:02.124 31,899 kbps 37,971 kbps 01:05:21.918 36,154 kbps 01:03:59.627
35,739 kbps 01:05:59.997 166,308 bytes 417,178 bytes 01:09:31.000
11 1:12:26.008 0:07:46.174 31,109 kbps 37,271 kbps 01:15:56.677 36,025 kbps 01:15:52.673
35,891 kbps 01:15:47.668 162,187 bytes 336,224 bytes 01:12:38.020
12 1:20:12.182 0:06:22.882 31,774 kbps 37,274 kbps 01:26:33.062 35,970 kbps 01:23:33.883
35,671 kbps 01:22:43.249 165,657 bytes 423,317 bytes 01:26:03.074
13 1:26:35.064 0:09:06.087 31,406 kbps 37,355 kbps 01:28:49.240 36,047 kbps 01:28:45.236
35,872 kbps 01:28:13.621 163,738 bytes 396,789 bytes 01:28:21.337
14 1:35:41.152 0:09:12.927 31,797 kbps 38,459 kbps 01:44:15.415 36,196 kbps 01:44:11.411
35,928 kbps 01:39:05.147 165,777 bytes 357,119 bytes 01:36:07.344
15 1:44:54.079 0:05:40.631 31,515 kbps 39,236 kbps 01:45:21.314 36,039 kbps 01:47:32.988
35,944 kbps 01:47:51.882 164,304 bytes 387,448 bytes 01:49:22.264
16 1:50:34.711 0:08:27.089 31,882 kbps 41,044 kbps 01:56:37.949 36,261 kbps 01:53:01.149
36,041 kbps 01:52:56.144 166,220 bytes 476,026 bytes 01:52:44.591
17 1:59:01.801 0:08:11.908 31,819 kbps 40,163 kbps 02:05:37.488 36,071 kbps 02:05:02.953
35,496 kbps 02:05:58.676 165,890 bytes 564,068 bytes 01:59:12.228
18 2:07:13.709 0:07:51.596 33,665 kbps 39,442 kbps 02:10:52.886 36,159 kbps 02:08:03.008
35,901 kbps 02:10:12.554 175,516 bytes 362,899 bytes 02:12:40.869
19 2:15:05.305 0:07:09.512 33,679 kbps 38,752 kbps 02:16:38.440 36,104 kbps 02:17:17.812
35,910 kbps 02:21:53.296 175,589 bytes 411,143 bytes 02:15:35.001
20 2:22:14.817 0:07:38.207 19,491 kbps 37,492 kbps 02:22:21.407 35,975 kbps 02:22:40.593
35,886 kbps 02:22:32.877 101,625 bytes 428,093 bytes 02:28:43.581
STREAM DIAGNOSTICS:
File PID Type Codec Language Seconds Bitrate
Bytes Packets
00003.M2TS 4113 (0x1011) 0x1B AVC 8992.859 31,291
35,174,145,794 191,289,943
00003.M2TS 4352 (0x1100) 0x86 DTS-HD MA eng (English) 8992.859 4,658
5,235,727,180 29,856,676
00003.M2TS 4353 (0x1101) 0x81 AC3 fra (French) 8992.859 640
719,444,480 4,215,495
00003.M2TS 4354 (0x1102) 0x81 AC3 spa (Spanish) 8992.859 640
00003.M2TS 4355 (0x1103) 0x81 AC3 eng (English) 8992.859 224
251,805,568 1,405,165
00003.M2TS 4608 (0x1200) 0x90 PGS eng (English) 8992.859 41
46,499,164 264,945
00003.M2TS 4609 (0x1201) 0x90 PGS eng (English) 8992.859 44
49,804,964 283,782
00003.M2TS 4610 (0x1202) 0x90 PGS fra (French) 8992.859 39
43,611,048 249,427
00003.M2TS 4611 (0x1203) 0x90 PGS spa (Spanish) 8992.859 34
38,012,754 218,683
00003.M2TS 4612 (0x1204) 0x90 PGS por (Portuguese) 8992.859 34
38,178,693 219,683
00003.M2TS 4613 (0x1205) 0x90 PGS fra (French) 8992.859 0
396,875 2,272
00003.M2TS 4614 (0x1206) 0x90 PGS spa (Spanish) 8992.859 0
371,396 2,132
QUICK SUMMARY:
Protection: AACS
BD-Java: Yes
Playlist: 00003.MPLS
Length: 2:29:53
Video: MPEG-4 AVC Video / 31290 kbps / 1080p / 23.976 fps / 16:9 / High Profile 4.1
Audio: English / DTS-HD Master Audio / 5.1 / 48 kHz / 4658 kbps / 24-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 24-bit)
Audio: French / Dolby Digital Audio / 5.1 / 48 kHz / 640 kbps / DN -4dB
Audio: Spanish / Dolby Digital Audio / 5.1 / 48 kHz / 640 kbps / DN -4dB
Audio: English / Dolby Digital Audio / 2.0 / 48 kHz / 224 kbps / DN -4dB
Subtitle: English / 41.365 kbps
Subtitle: English / 44.305 kbps
Subtitle: French / 38.795 kbps
Subtitle: French / 0.353 kbps
Subtitle: Portuguese / 33.963 kbps
Subtitle: Spanish / 33.815 kbps
Subtitle: Spanish / 0.330 kbps
Blu-ray IMAX File size: 47.70 GB
Bitrate: 31.30 mbps
Code:
Total Video
00003.MPLS AVC 2:30:24 44,811,589,632 45,175,023,272 39.72 31.30 DTS-
HD Master 5.1 4659Kbps (48kHz/24-bit)
Code:
DISC INFO:
Disc Title: TF_2_D1_AC_BSE
Disc Size: 45,175,023,272 bytes
Protection: AACS
BD-Java: Yes
BDInfo: 0.5.3
PLAYLIST REPORT:
Length: 2:30:24 (h:m:s)
VIDEO:
MPEG-4 AVC Video 31297 kbps 1080p / 23.976 fps / 16:9 / High Profile 4.1
AUDIO:
DTS-HD Master Audio English 4659 kbps 5.1 / 48 kHz / 4659 kbps / 24-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps
/ 24-bit / DN -4dB)
SUBTITLES:
Presentation Graphics English 41.228 kbps
Presentation Graphics English 44.318 kbps
Presentation Graphics French 38.665 kbps
Presentation Graphics French 0.352 kbps
Presentation Graphics Portuguese 33.859 kbps
Presentation Graphics Spanish 33.695 kbps
Presentation Graphics Spanish 0.329 kbps
FILES:
00003.M2TS 0:00:00.000 2:30:24.932 44,811,589,632 39,722
CHAPTERS:
9 0:54:56.543 0:08:50.196 31,475 kbps 38,861 kbps 00:57:48.298 36,034 kbps 01:02:38.379
35,804 kbps 01:02:33.374 164,096 bytes 454,609 bytes 01:03:16.626
10 1:03:46.739 0:09:02.124 31,899 kbps 37,971 kbps 01:05:44.774 36,154 kbps 01:04:22.483
35,739 kbps 01:06:22.853 166,308 bytes 417,178 bytes 01:09:53.856
11 1:12:48.864 0:07:46.174 31,109 kbps 37,271 kbps 01:16:19.533 36,025 kbps 01:16:15.529
35,891 kbps 01:16:10.524 162,187 bytes 336,224 bytes 01:13:00.876
12 1:20:35.038 0:06:22.882 31,774 kbps 37,274 kbps 01:26:55.919 35,970 kbps 01:23:56.740
35,671 kbps 01:23:06.106 165,657 bytes 423,317 bytes 01:26:25.930
13 1:26:57.921 0:09:06.087 31,406 kbps 37,355 kbps 01:29:12.096 36,047 kbps 01:29:08.092
35,872 kbps 01:28:36.477 163,738 bytes 396,789 bytes 01:28:44.193
14 1:36:04.008 0:09:12.927 31,797 kbps 38,459 kbps 01:44:38.272 36,196 kbps 01:44:34.268
35,928 kbps 01:39:28.003 165,777 bytes 357,119 bytes 01:36:30.201
15 1:45:16.935 0:05:40.631 31,515 kbps 39,236 kbps 01:45:44.171 36,039 kbps 01:47:55.844
35,944 kbps 01:48:14.738 164,304 bytes 387,448 bytes 01:49:45.120
16 1:50:57.567 0:08:36.098 31,898 kbps 38,559 kbps 01:57:51.355 36,198 kbps 01:57:05.810
35,847 kbps 01:55:55.990 166,301 bytes 507,551 bytes 01:53:10.325
17 1:59:33.666 0:08:11.949 31,850 kbps 40,163 kbps 02:06:09.395 36,071 kbps 02:05:34.860
35,468 kbps 02:07:31.560 166,054 bytes 564,068 bytes 01:59:44.135
18 2:07:45.616 0:07:51.596 33,665 kbps 39,442 kbps 02:11:24.793 36,159 kbps 02:08:34.915
35,901 kbps 02:10:44.461 175,516 bytes 362,899 bytes 02:13:12.776
19 2:15:37.212 0:07:09.512 33,679 kbps 38,752 kbps 02:17:10.347 36,104 kbps 02:17:49.719
35,910 kbps 02:22:25.203 175,589 bytes 411,143 bytes 02:16:06.908
20 2:22:46.724 0:07:38.207 19,491 kbps 37,492 kbps 02:22:53.314 35,975 kbps 02:23:12.500
35,886 kbps 02:23:04.784 101,625 bytes 428,093 bytes 02:29:15.488
STREAM DIAGNOSTICS:
Bytes Packets
00003.M2TS 4113 (0x1011) 0x1B AVC 9024.766 31,297
35,306,180,471 192,008,034
00003.M2TS 4352 (0x1100) 0x86 DTS-HD MA eng (English) 9024.766 4,659
5,255,709,756 29,969,999
00003.M2TS 4353 (0x1101) 0x81 AC3 fra (French) 9024.766 640
721,996,800 4,230,450
00003.M2TS 4354 (0x1102) 0x81 AC3 spa (Spanish) 9024.766 640
00003.M2TS 4355 (0x1103) 0x81 AC3 eng (English) 9024.766 224
252,698,880 1,410,150
00003.M2TS 4608 (0x1200) 0x90 PGS eng (English) 9024.766 41
46,509,728 265,007
00003.M2TS 4609 (0x1201) 0x90 PGS fra (French) 9024.766 39
43,618,143 249,473
00003.M2TS 4610 (0x1202) 0x90 PGS spa (Spanish) 9024.766 34
38,011,405 218,676
00003.M2TS 4611 (0x1203) 0x90 PGS por (Portuguese) 9024.766 34
38,197,062 219,785
00003.M2TS 4612 (0x1204) 0x90 PGS eng (English) 9024.766 44
49,995,821 284,892
00003.M2TS 4613 (0x1205) 0x90 PGS fra (French) 9024.766 0
396,875 2,272
00003.M2TS 4614 (0x1206) 0x90 PGS spa (Spanish) 9024.766 0
371,396 2,132
QUICK SUMMARY:
Protection: AACS
BD-Java: Yes
Length: 2:30:24
Video: MPEG-4 AVC Video / 31297 kbps / 1080p / 23.976 fps / 16:9 / High Profile 4.1
Audio: English / DTS-HD Master Audio / 5.1 / 48 kHz / 4659 kbps / 24-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 24-bit /
DN -4dB)
Subtitle: English / 41.228 kbps
Subtitle: English / 44.318 kbps
Subtitle: French / 38.665 kbps
Subtitle: French / 0.352 kbps
Subtitle: Portuguese / 33.859 kbps
Subtitle: Spanish / 33.695 kbps
Subtitle: Spanish / 0.329 kbps
