AVS › AVS Forum › Display Devices › Plasma Flat Panel Displays › Pioneer 9G IP control or Ethernet control
post #1 of 3
Hello,
one simple question: is it possible to change the channels or switch the tv on or off per ethernet? I found the RS232 Codes for the Kuros but not the Ethernet-Codes. I used the search before, but i didn't find an answer. The Pioneer-Homepage "says" "IP Control" but not more details.
I have a 600A, i think it is nearly the PRO-151FD.
Thanx.
Greetings from Germany
Thomas
post #2 of 3
Hi, the 500A (or US 151FD) does not support Control over IP.
post #3 of 3
it looks like the european users are out of luck :-(
I also have pioneer KURO 500A and was hopping i could set up control over IP..
i guess rs232 should be fine ok ( using irule & ip2sl gateway ) but dont have rs232 codes... been looking all around the web but w/o luck. could you please post a link where i could find the codes?
pioneer sc lx-82 rs232 codes too
rgdrs
