Time for another update. After painting the inner bulkhead black I realised that it would still reflect a fair bit of light, especially directly above the screen. All the walls were going to be covered with black wallpaper also. After using Fedileo velvet for the ceiling everything else looked grey by comparison. So iv'e now decided to cover the bulkheads and walls in Fedileo velvet.
After about almost 3 hours just trying to attach one strip across the front bulkhead I wished I had never changed my mind. Its was a total NIGHTMARE putting it up. It's like putting contact on a giant textbook....upside down. lol It has a self adhesive backing that is so sticky that once it touches any surface its stuck for good. If you try and pull it off, the velvet just falls apart. The final result does look very nice though. I guess I'll keep at it. Gotta love a bat cave
Here are a couple of pics showing the start and finished job. The photos are pretty bad. It's hard to get a good pic of the velvet.
Anyone want to buy 10 rolls of black wallpaper?
Uploaded with
ImageShack.us
Uploaded with
ImageShack.us
The next task was the double doors. They were both attached a few weeks ago but they shifted between now and then. The door frame couldn't handle the weight of both doors and started to bow. We had to take them both off and reinforce the frame and plane a few bits off both doors.
Pics below.
Uploaded with
ImageShack.us
