AVS › AVS Forum › Display Devices › Screens › Screen Help Needed (pics attached)
post #1 of 3
I am looking to put a fixed screen in my family room area and need advice in regards to what screen I should choose. These pics were taken around 3pm in the afternoon.
I will be purchasing either an Epson 8100 or a Panny AE4000 for this room. I live in California in the Bay Area. I do not know where I can go to look at screens so any advice or pics of people with similar setups to what I am truying to do would be greatly appreciated.
I know the BDII may work in this setup but it is fairly expensive. Has anyone seen the Vutec Silverstar in person or is there another recommended brand. I will not be getting a HP screen as the projector will be ceiling mounted. Thanks in advance for any and all suggestions.
post #2 of 3
Before I plopped down a hunk of change for a high end screen i would work on getting the room more projector friendly. Need darker walls, at least the projector wall and most important you need to block off a lot more of the light coming into that room. Other wise you will only get satisfactory use out of the projector at night.
post #3 of 3
Once our plantation shutters come in there will be hopefully alot more light blocked out. As for the painting the wall darker, I do not have the WAF on that. She is fine with the projector being setup here as long as the color scheme does not change.
  Back to Forum: Screens
