Originally Posted by Solution-Bubbles
Hey,
I have a question concering lossless audio on Blu-ray:
Imagine two Blu-ray of the same movie. They both have a DTS HD-Master track with exactly same parameters except for the bitrate. Blu-ray 1 offers a 1000 kbps higher bitrate than Blu-ray 2.
My question is: does Blu-ray 1 sound better than Blu-ray 2 when encoded with a setup capable of lossless formats? Or is there no difference once they are both encoded?
If this is the wrong place to ask, please put my question into the right area of the forum.
Hey,
Lossless audio codecs are variable bit rate.. you cannot encode the way you are suggesting...
The codec uses as much data as needed to recreate an exact reproduction of the PCM that was fed into the encoder.
It isn't user selectable.
