AVS › AVS Forum › Display Devices › LCD Flat Panel Displays › Need help diagnosing problem with Samsung LNT-5271F (Tech advice needed!)
post #1 of 15
SAMSUNG LNT-5271F ISSUE. IN SOUTH FLORIDA. ANYONE LOCAL FOR REPAIR?
I was told to start a new thread on this.
Can anyone tell me whats going on? If someone can reference the exact part I need, I don't mind fixing it myself. I'm out of the warranty period as of June. owned.
Starts up and lasts for about 10 minutes and then disappears. Then reappears! Starting to get SUPER ANNOYING! Its on every source. When I unplug everything it still shows up....so its not source related. It even happens with I turn off the 120hz feature and also in game mode. Weird.
I would appreciate any fellow techies helping out below and pay mega bucks for a repair house call.
Pics below.... Thx
It only shows up on the bottom right side of the screen.
post #2 of 15
to the top. looking for input
post #3 of 15
I don't think there are alot of techs lurking in this forum.
When it happens, compress the lower right quadrant of the bezel with your hands. If it fixes it, it could be a simple (relatively speaking) mechanical problem.
post #4 of 15
OK, I squeezed it and kinda pushed backwards. It flexed and the problem went away. When the problem came back I squeezed it again. Problem went away. What exactly does this mean? Thx for the info.
post #5 of 15
My set is having the same problem its right around the 2 year mark. I havent been able to find out alot on this problem yet as its hard to describe but a picture says 1000 words
post #6 of 15
That's a good sign! That means connection(s) in that corner is loose and all u have to do is tightening it up.
Look for screws that hold down the bezel. If they are screws at that corner, simply tighten the screw(s) up, one quarter turn at a time, don't overdo it.
If that doesn't work then u have to disassemble the unit and look inside and go from there.
Post pix, am sure other ppl will find that useful.
post #7 of 15
ACEdubs, i think it may be the FRC board.
post #8 of 15
ACEdubs, any luck? My screen is still messed up.
post #9 of 15
Bad news. LCD panel itself. Squeezing the area at the edge confirms this, three options:
Replace panel ($$$).
Buy new better LCD TV (samsung not a problem still. Any makers can get affected by a failing panel anyway and is same technologies in how it is constructed).
Send panel to LCD panel repair to rebond the bad connection of tape circuits (there is several businesses found on google).
Your LCD of this vintage has T-CON board is at top center and is not the problem since this usually cause noise or no picture whole panel itself.
Newer Samsung LCD TVs (starting this late 2008 and 2009) their panels is flipped 180 with T-CON at bottom so LVDS cable is now shorter run and allows T-CON board and Y lines buffers to run cooler).
Cheers, Wizard
post #10 of 15
the problem may be fixed temporarily by pushing the cables against the screen.... and the fix could last for years..... with minor adjustments every 6 months (similar to oil change... every six months...)...
Boky
post #11 of 15
I am having the exact problem with my lnt5271,just wanted to know if anyboby has had this problem serviced,and exactly what repairs were needed?
post #12 of 15
I took the back cover off and saw nothing out of the ordinary. So I've been dealing with the problem ever since.
post #13 of 15
I am starting to have this problem as well.
So are you just pressing on the screen when you have it? How long does it go away?
Did you ever contact Samsung?
post #14 of 15
its failed tab bond(s) you can find a good thread on here that a guy put together on his Sony that had the same problem
this is a well known defect of these panels from 2007 that both sony and samsung used the difference sony actually acknowledged the problem and is still replacing peoples panels free of charge while Samsung is doing what samsung does best and ignoring its disappointed customer base
in effort to halt the incoming samsung fanboi rage i will simply say this.
Samsung does make good products generally speaking but their treatment of customers either still in warranty or out of warranty is terrible and there is tons of evidence to be found to show this and that is why i will never buy a Samsung product again or recommend them to friends/family.
edit:
found the thread with detailed information on how to "temporarily" correct the problem by applying pressure to the problem tab bond(s)
http://www.avsforum.com/avs-vb/showt...4#post17433564
post #15 of 15
My problem is getting worse. Did any of you get yours fixed?
I called samsung And they claim they have never heard of this problem and told me to call a local repair shop.
3000 tv useless after 3 years. I won't buy samsung again. Very upsetting.
