AVS › AVS Forum › Audio › Subwoofers, Bass, and Transducers › Paradigm Sub 1 and Sub 2
Paradigm Sub 1 and Sub 2 - Page 45
post #1321 of 1444
Originally Posted by Warpdrv View Post
They are completely separate software and hardware kits... The software is encoded to recognize the product that it was made for, so you cannot exchange the two.... The PBK software will recognize the serialized mic the comes with the kit and upload the correction files to the sub itself....
Wow, that's stupid on their part.
Friends that DIY don't let friend spend this kind of money on subs.... Help a brotha out... Help him BUILD a nice pair of LMS's or a dual opposed rig there buddy, and get him more bang for the buck...
I'm not a fan of the LMS. It's too expensive for what it offers, and can bottom with expensive consequences. When I had one, it sounded no different than my Maelstrom-X Mk. I. I much prefer the Aurasound NS18-992-4A to the LMS. It doesn't sound materially different from my Mael-X either, but it looks so much cooler. (That's the only reason I swapped, truth be told. I wanted all five of my main system subs to use Aura NS-series drivers.)
I agree with you that the Paradigm is not the best solution. Three or four SVS SB12's and an unbalanced miniDSP set-up by someone competent (even yours truly) will provide far better sound than any single-sub system. And one can't build an Peerless XXLS12-based sub for meaningfully less than SVS will sell theirs to you for. It's really the standout bargain in subwoofers today.
As for a dual-opposed, I don't do cabinetry, though. I design my subs and outsource cabinetry to artisans. Besides, this dude changes gear more than is healthy, so resale value matters to him.
Originally Posted by Rod#S View Post
If memory serves the Sub 1 and Sub 2 both come with the PBK, it doesn't have to be purchased separately.
The dealer to whom we spoke wanted $100 extra for it. Plus tax. Whether that was just profiteering or not, or annoyance that someone wanted to special order a part rather than picking up something he had in stock, I don't know.
post #1322 of 1444
That dealer was trying to screw you. It comes with the Sub 1 or Sub 2. When the Sub is ordered it should come with the PBK and not have to be special ordered. What I don't remember is if it came in the sub box
post #1323 of 1444
Have a look on Paradigm's website; it says the PBK is included with the SUB 1.
No, it doesn't come in the box, it ships as a separate item.
post #1324 of 1444
Originally Posted by Billybobjimbob View Post
Anyone with a Sub2 watched Ghost Protocol ? My sub (this is mt second one) cut out again during one scene (where the car crashes into the river after being shot at). i think its due a firmware upgrade as the original sub2 had its cut out threshold too high and i think Anthem/Paradigm did a firmware update to lower the cut out threshold. Its late here so im going to look for more info on this tomorrow.
I watched the scene last night with a couple of different volumes. I didn't experience any cut outs but maybe I didn't listen to it as loud as you did. For reference not that it matters I have the sub dialed in a 12:00, set to -5 on the MRX and had the MRX at -15 (maybe -10 too) and nothing.
post #1325 of 1444
Have you run PBK on the Sub 2 and ARC on the complete system ?
Reason I ask is your -5db setting.
After PBK and then an ARC setup, ARC should have reset the Sub 2 to a setting less than 12:00 and the MRX result for the Sub 2 should be around plus/minus 1db
post #1326 of 1444
Yeah I did both. I need to re-run ARC with my sub turned down a little hence the -5 setting. But My room is being reconfigured with furniture and I don't want to re-run until I am done.
post #1327 of 1444
Ive been given the firmware update by a friend for the Sub2, will update once ive installed this
post #1328 of 1444
I didn't know there was an upgrade and to be honest, I don't know what I am running on mine. I juts never had a problem. Hope it works out. Keep us posted!
post #1329 of 1444
So, as you guys know, my first sub 2 needed to be replaced because during high db lfe scenarios the sub would make a loud popping noise and then shut itself off.
So I went through the hassle of getting the second sub 2 and the second new sub2 did the same thing. Instead of replacing this one, tech support had me install a firmware update that would fix the problem. This worked fine in that it did eliminate the loud pop and shut off.
However, after several months of listening, I have now noticed a loud mechanical "bottoming out" sound during high db lfe scenarios from a variety of movies....
you can listen here. this is the scene in latest xmen prequel (kevin Bakin holds exploding grenade) should soundlike one solid bass note:
http://youtu.be/HQJSwqp3UjI
After a month of troubleshooting with tech support they concluded that they could not reproduce the issue in house and are telling me that they want to send yet another new sub 2 to replace the one I currently have. Perhaps this happened due to the loud pop prior to shut off?
I have asked them that perhaps there is something wrong with the lfe output on my D2. Unfortunately, no one around here in Denver (my dealers) or anthem/ paradigm seems to have the desire or ability to supply me with another pre/pro or receiver with hdmi i/0 and xlr output to test with to determine if the issue still happens when the D2 is removed from the chain.
Very frustrating. I am now in the position where I will have to return both the D2 for repair/analyisis and then deal with the exhange process of the sub 2 for the THIRD time.
This will be the THIRD return and or exhange of my D2 as well.
I want to pull my hair out when I think of A) having my home theater shut down for a month and B) having to move the SUB2 AGAIN.
post #1330 of 1444
I watched the video and it is not good. I can only see one driver. Are all of then doing the same dance ?
How about feeding it a full range signal from the D2, say the LF or RF or center and see what the the drivers do.
I definitely would send both the Sub 2 and the D2 together if you can't solve this.
post #1331 of 1444
yes... i believe all of the drivers are doing it. however, it is very difficult to determine the drivers that are faulty by ear. I really can not tell.
what would be a good example of a full range signal? I suppose I could just hook up the LF xlr out to the sub2, set the sub setting in the d2 to "none" and then play the same sequence out of any movie that induces the problem through LFE?
post #1332 of 1444
Don't feel so bad, you are not the only one. It took Paradigm THREE replacement pairs of S8's v.3's before I got a "good" pair. I also had the woofer replaced in my SUB 25 once. Haven't bothered to really test out the replacement as I am afraid of what I would find in doing so... I also had THREE MRX receivers that were faulty, so I gave up on those.. But don't worry, I am sure in the end that Paradigm will fix the issue for you no matter what it takes. They are really good that way, there is no doubt about it. HUGE hassle for you though!
post #1333 of 1444
I was suggesting using one of the other audio outputs to make sure the D2 sub signal is not the problem.
post #1334 of 1444
My laptop charger has died so just trying to find a new one and then i'll update the firmware.
Im assuming everyone else is doing ok with there sub2s?!
post #1335 of 1444
4 sub 2 in 4 corners with EQ. Who has dropped the money bomb on this setup?
Should sound like Zeus coming from olympus to impregnate you while in the form of a T-rex? ... You may not survive it but it might be interesting to watch while it lasts.
post #1336 of 1444
Updated the firmware earlier..i'll be watching a few movies tonight. I dont think either is bass heavy so i'll see how i go.
I'll try and get a few movies watched before i post any further updates:)
post #1337 of 1444
+1
post #1338 of 1444
Ive watched around 4-5 films since the fimware upgrade, and quite a few bass heavy scenes in these films and the sub has been fine:)
m-b-m-f, any updates with your ub2 scenario?
post #1339 of 1444
anyword on he sub shoot out? i live in markham and would love to be at that shoot out. I have a sub 25....or the shoot out can be at my place smile.gif
post #1340 of 1444
My Sub 2 just died, no sound at all. I was recalibrating as I had moved the sub and tried to set the sub level to 75db through the D2v and no sound at all. Fuse in the house is ok. Anyone know of a fuse, maybe in the amp before I email them?
PS, Did I mention I just started two weeks holidays and have plenty of unwatched blurays? frown.gif
John
Edited by studlygoorite - 7/22/12 at 7:14pm
post #1341 of 1444
John
John
Are you using the auto sense mode or a trigger to turn on the sub ?
Do you see the blue indicator light on ?
post #1342 of 1444
John
I was using Auto but neither work and there is no blue light.
post #1343 of 1444
I would check that there is AC power at the female end of the power cord plug that goes into the Sub2.
If using the Auto On make sure you have an LFE audio signal otherwise the Sub2 will not turn on
Check the audio source at the D2v is using sound mode using the sub
Make sure the sub cable is still plugged in at the Sub2 and the rear of your D2v
At a reduced volume level temporarily try a different audio signal source from the D2v.to trigger the Sub2 on
post #1344 of 1444
Tried all of this pal and still a no go, D2v is still sending a signal as my transducer in my chair still works and 240v still pumping as when I plug the power into the Sub 2 you can here the ever so faint "snap" of the connection being made.
post #1345 of 1444
Tried all of this pal and still a no go, D2v is still sending a signal as my transducer in my chair still works and 240v still pumping as when I plug the power into the Sub 2 you can here the ever so faint "snap" of the connection being made.[/quote
Well you tried everything. Time to call Anthem on the telephone.
Let us know what happens
post #1346 of 1444
Just received my replacement amp, installed, calibrated and good to go.
post #1347 of 1444
Thankfully the amp was removable and you did not have to ship the complete Sub2 back.
Sound any different ?
post #1348 of 1444
You're telling me, it sounds different in that I moved it back to the back corner where I get the most output as I was lacking some thump to the chest with music but I watched Thor again last night and it sounds awesome. Ran PBK then Velodyne Sub EQ to try and tame some of the boom then ARC. My graph on the Velodyne EQ was perfectly flat but as you can see, not so much after ARC, but still not bad.
John
ARC.JPG 159k .JPG file
post #1349 of 1444
John
The sub chart looks great.
i would like to see the LF and RF chart as well as the targets
post #1350 of 1444
