I was told by my dealer than production on the Sub 1 started this week, and they will start shipping next week. He said this first production run is only in Piano Black (what I ordered). I didn't ask him about the Sub 2.
Digs, Low-Frequency Extension is measured according to some obscure German standards "Deutsche Institut fur Normung" (DIN), but it is definitely not the -3 dB point in your room or my room.
For reference, the Sub 25 is listed at 9Hz DIN on Paradigm's site. The Sub 1 and Sub 25 are priced very similarly, but likely perform very differently. The Sub 25 can run off 240V and has a much bigger amp, so I'm sure it can play louder and deeper.
However, the Sub 1 should have a significantly lower group delay, i.e. it should be 'faster' or more musical. I base this on group delay measurements of the Martin Logan subs that use the same multiple opposed small driver design. Their group delay at 20 Hz is often half the value for 15" sealed subs.
