AVS › AVS Forum › Display Devices › LCD Flat Panel Displays › What problem is this?
post #1 of 13
Can anybody tell me what this is? I'm getting pretty tired of it, as it looks even more visible than in the pictures, especially in motion. Is it possible to return it or exchange it just for this problem at Conns? I wanted to trade it, a Samsung LN-T4061, for a Panasonic G10 or S1 Plasma. I've heard it looks great with an excellent value. I just can't go with an LED LCD knowing there's a plasma half-price and same or maybe better PQ. Sorry guys. Unless you convince me, I'm going with plasma.
post #2 of 13
Ewwww return, that does not look good at all, especially in the last picture, looks like comboniatin of banding and a bad panal.
Return it.
are you within your return periond for the store you bought it at?
post #3 of 13
Return it.
Hehe, I hope I am! It really does look nasty. It was in Conns, and I bought it in 2008. I think it has 3 year warranty. I really hope it does. I'm really not completely sure.
post #4 of 13
Ur amused. Clearly ur looking for an excuse to upgrade. OK, tell that to the wifey we agree it looks bad, after u messed with the settings.
post #5 of 13
Like I said, it looks way worse than what it looks like in the pictures. No, I didn't mess with the settings. This is all serious. And I'm only 18. Right now, by 'wifey' you mean 'mommy'.
post #6 of 13
Something is defintely broken. You should return it if you still can.
post #7 of 13
Thanks! I needed that extra confirmation.
post #8 of 13
did you keep your receipt and warranty information? You'll need all that .
post #9 of 13
Not really. To be honest, parents haven't yet payed it off completely. We're close though. Quite embarrassing really. Hehe. Is there a way to return or exchange it while in this process?
post #10 of 13
It is a little difficult to tell from the pictures but it appears to be liquid crystal injection contamination. During the LCD panel manufacturing hundreds of devices that look like eye droppers come down to inject the liquid crystals. If the liquid crystals are contaminated or the injectors withdrawn too soon (or too late) it will produce subtle white blobs evenly spaced in a symetric grid pattern. Is this what you are seeing?
post #11 of 13
You would have to find out if you have the extended warranty. If not, most sets have a 1 year manufacturer's warranty. Either way, I doubt you're within a return period if you bought it in 2008. If you bought it from the conns website, looks like they only have a 14 day return period, so your only option will probably be home repair.
post #12 of 13
Your TV is mad that you play Halo!!! JK... Or am I??? That looks horrible! I would definitely look into taking the set back. Or contact Samsung directly about the situation....
post #13 of 13
Whoa, nice answer. Very thorough. Yes, I guess that is what it is. And scottman, I think I do have one. I remember something about 3 years being mentioned.
Thanks everybody, I'm gonna try to find out this weekend if I can return this failed model.
