Originally Posted by rickardl
Yesterday I experienced audio drop outs combined with relay clicking for the
first time with my 3007.
It was a movie with a Dolby Digital 5.1 soundtrack recorded with my Humax HDPVR-1000C.
It occurs both with optical and HDMI audio connections.
It occurs sometimes with shorter intervals, say 2 minutes, and sometimes longer, say 10 minutes.
It occurs at the same places every time so I believe there is a fluctuation
with the Dolby Digital stream at those places.
Using the PCM track from the HDPVR does not cause any audible drop outs
or artefacts at those places with that movie.
I just confirmed that the audio drop out with relay clicking mentioned above is NOT a fault with the TX-NR3007.
I hooked up an old Yamaha RX-V1400 and connected it through optical to my HDPVR and yes, there was a significant audio drop out there as well.
Occurred at the exact same places so in this case, it is the dolby digital stream which is corrupt, the PCM audio track works fine.
