Yes you can easily use either zone 2 or 3 triggers. As long as you leave the power amp for zone 2 and 3 off you can use the triggers and not lose any channel processing as discussed in the manual.
I use an XPA-5 and use trigger 2 to power it on and off. In the Onkyo Setup Menu, section 2.1 "Speaker Settings" make sure you have Power to zones 2 and 3 set to "Not Act". The Zone Trigger will still work.
Originally Posted by ctviggen
I don't have an Onkyo model as yet. My room has been under construction for way, way too long. I'm looking at buying a receiver, and Onkyo is one I'm considering (though I have all the amps I need unless I go to 9 channel). However, the recent discovery that there is no Zone 1 12V trigger has me rethinking Onkyo. I absolutely must have a 12V trigger in order to turn on two or more amplifiers.
Anyway, I completely gutted my room and ran cables for, say, 10.7, as I ran two center channels (in case one wants to reverse the room for some reason), 6 additional channels and two extra sets of speaker wire, meant to biamp the "front" R/L speakers. I could use these extra sets of speaker wire for heights, but they aren't placed correctly for widths. I also ran subwoofer wire to 7 independent locations around the room. Had I known about the wides/heights, I'd have run cable for them, too, even if I never used them.
I also have some cheap inwalls I could use for the heights, but it's not clear to me how much info is going to the inwalls/heights, so I don't know whether they would work in that application. They were originally purchased for surround duties in a different room.
Unfortunately, the drywall is up and painted. Surround speakers (Emotiva) go up this weekend. The carpenter finishes installing the wainscoting sometime soon (he just got married, so when he gets back from his honeymoon).
Anyway, how significant is the lack of a Zone 1 trigger? To me, this seems like a deal breaker. Do I have to use Zone 2 and Zone 3 as triggers for Zone 1? I need to turn on at least two amplifiers and an active crossover.
