Originally Posted by Jay5298
I have a question about Blu-ray discs with DTS-HD Master Audio 6.1 tracks. Can you use the THX modes with this type of audio? If I play a disc with a 5.1 track I can use either Dolby PLIIx Movie or THX Ultra2 Cinema and this duplicates the side surrounds to the rears as well as doing some processing correct? When I put in a 6.1 track (for instance Star Wars) my screen on the receiver says DTS Master Audio and not Dolby PLIIX Movie or whatever I have chosen as my processing. The only reason I ask is it was brought up in the "Star Wars" thread that episode IV ANH sounds a little harsh and some people suggested using a "THX" mode. From what I can see I can't use post processing when playing a 6.1 title, or somehow it's doing it behind the scenes and doesn't show on the receiver. Usually I wouldn't want to do any processing anyway but I just thought I would try this and see what the difference would be. I have a 3007 receiver.
Anybody?
Natch. The UVC (Ultimate Volume Control)...
