Originally Posted by MarcusG
After Audyssey The Front and Ceter Speakers were set to 40 Hz. I had failed to set them to 80. What happened when I was watching 2.0 channel source on the Uverse Box, is it was converting 2.0 to 5.0 (if you hit display on the remote) using THX cinema, Once I went back into settings and set the Front and Center speakers to 80, then it would began converting 2.0 to 5.1 using THX cinema.
Ah right - it's the way the Uverse box works that I didn't follow. Thanks.
Nobody seems to know. But there can't be any doubt that if you filter at 80Hz you will lose the information above that point.
Bear in mind that not every mixer puts stuff as high as 120Hz into the LFE channel, so it will be movie-dependent whether you hear the difference or not. If you just leave it at 120Hz then there will never be any doubt that you will get the full content the mixer intended.
Kind Regards,
Keith
