Originally Posted by Lt.Aldo.Raine
Yes i am using a true hd blu ray when trying to get it to work.....All the settings are correct as well. Like i said all other types of audio work....I can tell it is not true hd just by listening to it. When i try other blu rays that have DTS-MA tracks or whatever the audio is 10x better. I have only had this receiver for about 2 weeks and the receiver before had no problem detecting true hd....
The problem is most likely your PS3 settings, the Onkyo will see HD audio if the PS3 is sending HD audio. Unless you have a real defect with the 609
Make sure your 609 is set to dolby digital mode..
