AVS › AVS Forum › Audio › Receivers, Amps, and Processors › The Onkyo TX-NR3007/TX-NR5007 common questions/issues/hints/answers thread
The Onkyo TX-NR3007/TX-NR5007 common questions/issues/hints/answers thread - Page 3
post #61 of 4660
Originally Posted by iraweiss View Post
I wonder if there are also HDMI compatibility issues with the newer DCT-6416 design (large black panel on silver faceplate without III).
Comcast has a newer box in our area a 3400 so they tell me I will have to see if it is worth switching to. Just now everything works well and I have wasted so much time already. I know this should not happen and some still want to blame the receiver. But HDMI has been an issue since being introduced and there are a lot of issues with a lot of receivers, pre pros and source units. Some people never have a problem. this was my first so called major issue.
post #62 of 4660
Originally Posted by rickardl View Post
Unless someone else has another idea, I would suggest contacting Onkyo
about this.... But first, maybe the store where you bought it could swap it
for another sample to see if it behaves the same?
Thanks for your help, I contacted Onkyo again (I did it once already, at first it did not help). If no solution, I will return it. Keep you posted
post #63 of 4660
I just took the plunge and ordered a 3007 online. If my local Anthem/Integra dealer had ever gotten back to me about the Anthem upgrade options and/or the Integra pre/pros, I would probably have gone that route even if it was more money, but after initially speaking to him in person and then having him essentially ignore repeated emails, too bad for him.
At any rate, I have a question. I presently have an anthem AVM30 pre/pro and one 7 channel and one 2 channel separate amps in a bi-amped 7 channel configuration (with separate powered sub). Despite this, I am somewhat of a newbie on audio (this system came with my house). If I want to keep the bi-amped fronts, can I use 3007 as a pre/pro for the 7.1 setup but also use the Onkyo's internal amps for the high/wide speakers, thus getting a 9.1 setup without having to buy another 2 channel amp and without getting rid of bi-amping the fronts? Put another way, can you use the pre-outs on some channels and the onboard amps for other channels?
post #64 of 4660
rickardl,
On a side note, how do you find the XXX7 series compared to the 876 that u were using?
post #65 of 4660
Quick question on the REON implementation...
For any of you that have had the 906 or 876, is the REON implementation better in the XXX7 series (i.e. a better picture)?
post #66 of 4660
yes you can....
post #67 of 4660
Originally Posted by venkatesh_m View Post
rickardl,
Hard to make a full comparison so soon but at a first glance...
Allthough I don't use networking/usb or DSX, I find the 3007 one or two notches better than the 876.
First, the Audyssey setup seems to have matured, it found my speakers
at 40Hz instead of Full Range which is more correct, and it sounds much more refined.
Certainly Audyssey Dynamic Volume (now also with Light, Medium, Heavy) works a lot better.
The Reon is better now, taking plain DVDs (NTSC) and using the 1080p/24fps conversion works like a charm.
The Audio and Video buttons on the remote is handy for making adjustments without entering the GUI setup.
And do I need to mention the network/usb firmware upgrade feature?
But any major difference in performance so far? No. Maybe some more enhanced bells and some new whistles.
DSX might be interesting if I move to a new apartment/house.
post #68 of 4660
Thanks rickardl.
I noticed that when I moved from 875 to 876 the Audyssey was better as well, but that could have been the new mic. Good to hear that they keep improving.
The network/usb firmware upgrade is great.
post #69 of 4660
Thanks rickardl.
It is probably the mic which was different in 875 and 876 but they
also added Audyssey Dynamic EQ and Volume, right?
So it was probably a later generation of Audyssey inside as well.
The same goes for the x007, allthough the mic seems to be same,
they have added Audssey DSX which also implies a later generation of Audyssey inside.
post #70 of 4660
Anyone figured out if the blue mode is available in the x007 models?
This works for the 2008 models: ISFccc : DTR-8.9, DTR-9.9, DHC-9.9, TX-SR876, TX-NR906, PR-SC886 but I didn't get it to work when I tried it.
Blue Mode (Blue Only Filter):
If Blue Mode is On, R and G of output siginal become 0.
(To turn Blue Mode On/Off: From the front panel- push and hold "HDMI OUT" then push "MEMORY".)
post #71 of 4660
Anyone having problems with Audio and Video drop outs and possible handshake issues over HDMI please go read this post.
http://www.avsforum.com/avs-vb/showp...&postcount=263
Action is required to get Onkyo to do something about this.
post #72 of 4660
Thanks Adam!
I am including the text here as well as in the first post at the top:
Please post your issues with drop outs at the Onkyo Web site
Fellow TX-NR1007, 3007 and 5007 Onkyo owners,
Just got off the phone with Bob from Onkyo. Seems like I am the first person to complain about the audio/video dropouts and possible handshake issues to their web site. They don't and won't read outside forums or sources. So they are completely unaware that many people are having the same issues. They want to look into this problem, but according to them I am the only one who has submitted a complaint about it.
What we need is for everyone who is having this problem to go to the Onkyo site and report your issues with the units. This will get more attention and should lead to a firmware fix that all of us will benefit from.
Please go to the web page and fill in the forms and submit your complaint:
http://www.onkyousa.com/feedback_form.cfm
Thanks in advance for your cooperation in this effort.
For European owners:
http://www.eu.onkyo.com/feedback.html and/or
customercare@eu.onkyo.com
post #73 of 4660
rickardl,
Since you have done such a nice job listing all the functions and hidden menus for these new units. I thought you would be interested in adding this information.
http://www.avsforum.com/avs-vb/showthread.php?t=1193885
post #74 of 4660
rickardl,
Well, Blue Mode only, does not seem to work in the 2009 Reon equipped units.
At least, it can't be enabled/disabled the same way as it did in the 2008 models
which is why I posted the question above, both here and in the thread you included.
If it can be enabled somehow, I will add that.
Appended is the ISF document for the 2008 models, most of it is present
in the first post in this thread.
ISF_Adjustments.pdf 11.548828125k . file
post #75 of 4660
I have a quick question for the 3007 owners that I can't seem to find an answer to. I like to have the display on the front of the receiver turned off as I think it looks a lot cleaner. When pure audio mode is selected it essentially does exactly what I would want it to do. However it appears that you can't use pure audio in combination with the THX modes. This is a point of frustration for me as i tried to dim the display but that only makes the display darker and does not seem to turn it all the way off. Is there a solution for this or am I pretty much stuck? Thanks for the help guys.
post #76 of 4660
I am afraid you are right, I haven't seen any way to turn off the
display completely.
post #77 of 4660
display completely.
I had a busted 875 display before (everything else worked), had to change out 2 resistors, I believe you would need to mod it to mimic the busted resistors to turn display off/on.
post #78 of 4660
Do you mean that dimmest dimlevel would then be off?
post #79 of 4660
No. The display would never turn on although the set worked. In the end I had to change 2 resistors as mentioned in the 805 thread to bring it to live. But as I said, it was spoilt.
What I meant is if someone were to modify their set they probably need to work something around those 2 resistors to turn the display off. There is no way to switch off the display.
Sorry if I wasn't clear.
post #80 of 4660
Well, ok. It seems easier to put some black duct tape on the display...
post #81 of 4660
Don't know how I feel about covering a $2100 piece of AV equipment with duct tape You would think that that would be something that would be so simple to add in a firmware update. Maybe I should call Onkyo.
post #82 of 4660
Yeah, would be great.
Adding a piece of "virtual" duct tape to the firmware
post #83 of 4660
Well, it seems like small thing to add another step in the Dimmer cycle to turn off the diplay.
Setting the Display Brightness
You can adjust the brightness of the AV receiver’s display.
Press the [RECEIVER] button, and then press the [DIMMER] button repeatedly to select:
• Normal + VOLUME light on.
• Normal + VOLUME light off.
• Dim + VOLUME light off.
• Dimmer + VOLUME light off.
• Off + VOLUME light off.
Use the appropriate feedback form:
post #84 of 4660
I was called again today by Bob Elder with the Product Support Team for Onkyo. I had previously reported here, they wanted to see my unit and had offered to pay for shipping both ways. They estimated a 7-15 business day turnaround. I said not interested in losing my unit for a possible 20 or more days. I thought that was the end of it.
Well, today they called again and really want my unit. They offered to send me a new 5007 upon receipt of my unit. They offered to send me a prepaid box to ship my unit in.
So, it would seem that possibly we have gotten their attention. They have been testing a unit in house, but after two days of testing it has not exhibited the same problems. They are using a Direct TV hookup.
Please keep posting your problems at the Onkyo web site. Report them in writing. Even if you have previously called. It is working and may lead to a solution that will benefit us all.
Thanks again.
post #85 of 4660
Yesterday I experienced audio drop outs combined with relay clicking for the
first time with my 3007.
It was a movie with a Dolby Digital 5.1 soundtrack recorded with my Humax HDPVR-1000C.
It occurs both with optical and HDMI audio connections.
It occurs sometimes with shorter intervals, say 2 minutes, and sometimes longer, say 10 minutes.
It occurs at the same places every time so I believe there is a fluctuation
with the Dolby Digital stream at those places.
Using the PCM track from the HDPVR does not cause any audible drop outs
or artefacts at those places with that movie.
post #86 of 4660
I've come across my first bug as well. It's stopped responding to the "arrow/enter" buttons on the remote in "network/usb" mode. I have to use the "arrow/enter" buttons on the front of the amp to select and play songs on the network or USB stick. I'm guessing a reset will fix the problem but I don't want to loose my Audyssey settings.
Has anyone played their music over the network or USB stick ? It's not very good because the amp puts a short gap between tracks which is kind of annoying for continuous music. I've fed this back to Onkyo, hopefully they can do a firmware update with gapless playback.
post #87 of 4660
I setup Onkyo NR3007 last night and ran the audyssey which worked like a charm. It found all speakers including the heights and wides. The distances were spot on. I just moved from separates to this receiver and it sounds amazing.
My question to the experts is how do I activate wides. When I cycle through the listening modes I see PLIIx with DSX but only heights light up. I realize I can't have both wides and heights active at the same time but I want to activate 7.1+wides. I checked the zone 2 and is set at not act (?).
Any help is greatly appreciated.
post #88 of 4660
Have you tried the "Speaker Layout"-button on the remote?
You can configure for both front and wide but
you can only use either front highs or front wides at the same time.
You select what you use with the "Speaker Layout" button on the remote.
If you use surround back speakers, the speaker selection will be based on the combination of surround back and front high speakers, or surround back and front wide speakers.
post #89 of 4660
You can adjust the brightness of the AV receiver's display.
So there is a way to completely turn off the entire display? I wish the Volume ring would stay one but if it all has to go off thats fine too I guess. I tried cycling through the different brightnesses but it never went to completely off. What am I doing wrong
post #90 of 4660
Hi,
With the particularity that this only works in DPLIIx + DSX mode...
As in Audyssey DSX mode (either SB+FW or SB+FH) where SB speakers are supposed to be used, they are actually muted! No sound is coming out from SB in pure Audyssey mode.
So on this 5007 9.2 amplifier, only 7.2 channels are used in pure Audyssey DSX mode.
So maybe Onkyo ingineers could though rearrange this Audyssey DSX mode to finally produce a (VERY expected) 5.2 + FW+FH reproduction on the 5007?
Hugo
