AVS › AVS Forum › Audio › Audio theory, Setup and Chat › IF Power cables make a diffrence then why not?
IF Power cables make a diffrence then why not? - Page 45
post #1321 of 1754
Originally Posted by mcnarus View Post
Jesus H. Christ. Are you unfamiliar with the concept of level-matching?
Ahh, so you admit there would be a need to level match to get the system with two different cables sounding the same? Sounds like a detectable performance difference to me.
post #1322 of 1754
If that's your definition of a performance difference, fine. Then I'm not talking about a performance difference. I'm talking about a sound quality difference. Any difference that can be erased by a simple tweak of the volume knob is not a sound quality difference.
post #1323 of 1754
Everybody here will of course assume that all controls, source material, speakers and amps are set and untouched. Otherwise there is no AB comparison.
The ONLY variable will be the power cable which in the mega buck Hyperbole brand, will alter the "soundstage" spatiality, FR sonic intensity, purity and to a notably marked degree.
Oh and it will and fix dinner. Maybe with just a little kink of its insulation.
We are STILL waiting to hear the specific alterations that take place inside a power cable that create this wonder of nature.
1300+ posts and not one single explanation aside from "its too ethereal to use words to describe" or some such silliness.
Come on guys either post the technical details or just admit you have been snookered.
post #1324 of 1754
Originally Posted by Joe Skubinski View Post
Most dynamic loudspeakers have a decent off axis response, and we're talking about being 6-8 ft apart, so long as you are in front of them they will image. You of course do not necessarily have to get as close as possible, but to me it helped to exclude the room and find the minimum.
Seems like a very crude and subjective methodology. How do you decide how many times you repeat the experiment to get a baseline? Did you do blind testing with different cables and different people to make sure there's no bias? How do you choose source material for this?
post #1325 of 1754
That should be DOUBLE BLIND testing so no-one involved in administering the test knows which item is active at any point in time.
post #1326 of 1754
I don't think a double blind test is necessary in this scenario because the person administering the test has no way of impacting the outcome as long as the test-taker remains blinded (i.e. the equipment is kept out of sight).
Double-blind test are most useful in clinical settings where the investigator/doctor could accidentally give the subject/patient clues as to what treatment group they are enrolled in during the study/trial.
post #1327 of 1754
Originally Posted by jpjibberjabber View Post
It sounds like you might think there's a difference to be had. You just don't know what that difference-maker is, so instead of acknowledging that fact, you team up with your e-buddies and ridicule.
My advice if you don't know the answer to something is to not laugh at someone that is asking the question. They might not know either, but are at least trying to find some answer.
Hate to quote the entire post, but this is very good. I couldn't have said it better, although I do think one can improve response with better optical fiber materials. That can be a minor thing though, and it's nice to have another person with hands-on experience. Of course, you'll be labeled as a shill and, because you're in the industry and not toting the AVS party line, will be fired upon. Get ready.
I can get fired upon allday long , it doesn't bother me one bit. Experience there is no substitute. I just hope someone can benefit from my experience.
post #1328 of 1754
So you are saying that, if I use TOSlink IC (which has no return current), I could use ANY power cord without degrading my audio signal??
When I use the term "single ended system", I am referring to the normal RCA style jack input. The nature of that beast is that it does not control the ground currents when the two chassis are connected to a common safety ground.
To alleviate this, balanced systems are used, and as you mention, optical.
The direct answer is, optical will not suffer ground loop issues, therefore, the variation in ground parametrics such as inductance, resistance, and loop intercept area I speak of can have NO effect on a fiber based system.
If a line cord can affect a fiber based system, my first thought would be that there is a pathalogical problem with the equipment.
Balanced differential systems should be as impervious. However, the methods and geometries used in balanced design can still couple to ground loops, a la pin 1 problems, so caution in design is still warranted.
Cheers, John
post #1329 of 1754
Originally Posted by bluesky636 View Post
Please. I am only a systems engineer who designs classified intelligence collection systems for an angency of the federal govenment. Please explain to me (to all of us) in easy to understand terms what the heck anything you just said has to do with "imaging."
To what level would you like the explanation? From your description, I cannot glean specifically what you do. Low level RF, low noise analog, server based data aquisition... So I'm not sure where to begin.
In general, we "image" based on the relationship of the sound each ear receives. The relationships we use are the level difference between the ears and the difference in time between when each ear hears the sound. The first is IID, Interaural Intensity Difference, the second is ITD, or Interaural Timing Difference.
Pro apps, such as Gizmo, and in the recording studio, do not consider, manipulate, or even worry about the time difference between left and right. They use ONLY the difference in level between the channels to position the "image" somewhere within the sound field.
Anything in the reproduction chain which can alter the relationship in intensity or timing between the left and right channel can alter the resultant image we perceive. The level of sensitivity humans have to this alteration is in the single digit microsecond range, 2 to 5 uSec is typically bandied about.
Ground loop problems can rise to level of effect beyond these thresholde.
It is a difficult task to even measure this kind of timing accuracy for frequencies in the 200 hz to 12 Khz range, but peered reviewed publications clearly show humans are sensitive at that level.
Please ask specific questions, and I will answer them as best as I can..
Cheers, John
post #1330 of 1754
Hi John,
You may have covered this but I don't recall... What cable topology are you using when making these measurements?
The cable topology per se is unimportant to the discussion.
One source, two single ended outputs, one amp, two single ended inputs, two 3 prong line cords, two coaxial IC's. Source output Z zero (for clarity of discussion), amp input z 10K.
When the source pushes say, 1 volt at 20 hz in the right IC, 100 uAmp flows in the IC center conductor. Current always requires a return path, so how does the 100 uAmp get back to the source? By the path of least resistance.
Examine the paths that are available...you have two IC shields as return paths, and the safety grounds via the duplex outlet.
Without the safety ground, the 100 uA will split between the IC grounds, 50 uA in the right, 50 uA in the left. With a massive safety ground, the bulk of the return current will flow through the ground, NOT the IC shield.
As long as return current flows through the safety ground, the actual loop will be picking up any and all time varying magnetic fields. Faraday's law of induction will cause a voltage to be generated around that loop, and that voltage will appear across the 10k input resistance of the amp.
Let's recap the salient point:
The return current does NOT for the most part, flow back to the source via the outer shield of the coax that the signal came in on. For a shield to actually work, ALL the return current MUST flow back on the shield.
For a balanced pair to "shield", in this case by centroid proximity, all the current in one wire MUST return via the other wire.
This is the standard conceptual understanding within the EMC field.
Cheers, John
post #1331 of 1754
Actually, it's not that bad. I personally wouldn't have moved closer to the speakers though, as that alters the time of flight from opposing speakers and alters the room interaction. I would have recommended maintaining the same angular topology.
But you are absolutely correct. It is subjective, dependent on subject material, and first and foremost, only applicable to Joe. Nobody else.
He cannot claim that his results apply to others, his methodology has no statistical significance which can be applied to others.
Essentially, others can only take his word, or trust his results..nothing more, nothing less.
Cheers, John
post #1332 of 1754
This was one of many experiments I created to determine what physical properties within the cable were causing sonic change. Since a scope was of no help and I really could not foresee what any available test equipment could tell me about what I was hearing in this context, I continued to use the only available test gear, my ears.
For example, I made a remote switch to be able to instantly and randomly change between 2 pairs of interconnect, and after using that for a month or so, I determined the results were being skewed by the emotional stress of having to make an instantaneous decision at the time of change. It was a useless method to compare, so shelved that box.
Source material was typically less complicated and clean CD music, at the time mostly female vocals such as Rickie Lee Jones. For me this was the 'sound' I was most familiar with, the sound of my mothers voice seemed to be ingrained in my brian since birth, so I concentrated on trying to recreate what was to me a 'known sonic signature' in playback.
As years went on I experimented with different conductor materials, dielectrics, shield materials, and cable topologies, listening to each configuration for as many months as it took to fully grasp it's 'signature' with the system, while attempting to mentally exclude variables learned from previous tests. In hindsight what was really happening over time was I was training my objective brain (I've always been quite technical) how to subjectively evaluate using my ears.
post #1333 of 1754
Cheers, John
What I do specificically has no bearing on your ability to provide a simple, straightforward answer to the question. I will now ask the question (again) as simply and straightforward as I possibly can:
How does a power cable affect imaging?
post #1334 of 1754
Cheers, John
Agreed, and no doubt in my mind that alternate return current paths would be a huge culprit, particularly since those paths are quite complex as they travel throughout the system. To me this is one of the reasons why a very complex system is much more difficult to invoke a change by changing any one cable- you would have to improve key points within the large system, and finding them would be mostly by trial and error.
In a basic 2 channel system the source and the amplifier, and in video the source and display device, tend to significantly affected in overall performance by our AC cords.
The reason I had asked was that standard coaxial designs with a braided and/or foil shield never sounded good- no matter what I did they had resolution limitations particularly at higher frequencies, that could not be avoided. However, there was one design that worked very well, where the shield was of equivalent gauge to the center- a solid shield- not the most flexible of cables, but it worked well.
post #1335 of 1754
Could you also explain what correlation measuring the minimum voltage required for imaging using different cables has to listening at normal volumes?
I'm having a hard time understanding what purpose this experiment serves.
post #1336 of 1754
Alas, your area of expertise does indeed determine how best I can explain.
The fact that you repeat a question that was answered speaks clearly on what you understood, and what you did not.
I note with interest that you cut out the explanation of how we image. Does this mean you understand that entirely and consider it a moot point, or are you neglecting it because you do not understand it? Understanding how we image is required to understand what to look for and measure with respect to any changes that can alter imaging.
If my explanation of localization was insufficient, I can elaborate.
If my explanation of loop topology was insufficient, I can elaborate.
If my explanation of Faraday's law of induction was insufficient...you get the gist.
The same applies to the EMC inferences, the pan pot, single ended, sweet spot, return current, etc...
The complexity of the issue requires some basic understanding of every topic I just mentioned. Reduction of the answer to some arbitrarily simplistic description will lose salient content.
As I said, please ask questions.
Cheers, John
post #1337 of 1754
You will of course understand my next question: What "proof" do you have to support this assertion of "significantly affected" performance.
While I have certainly supported an argument reflecting the system geometry and causal paths involving IC's and power cords, I am also of the mindset that statements of absolute effect require absolute proof.
It is necessary to consider all the electrical parameters of the cables. This discussion at present considers the base resistance of the shield, the connector contact resistance, the power cord safety ground resistance, and the various inductaces...IC to IC loop, IC to power safety ground loop, the IC inductance, capacitance, and dielectric coefficient.
How you got to "resolution limitations" is also interesting, and also begs the question of "how did you measure that"?
In essence, I ask the same of you that everybody else does. The fact that I have a decent understand of the complexity of the system, the measurements, our hearing, production methods and costs allows me to be a tad more laid back in the discussion. I wish others would do the same, instead of emotional outbursts which get in the way.
Cheers, John
post #1338 of 1754
Cheers, John
Alas, my area of expertise is classified and NOYB.
I have no intention or interest in getting into a line-by-line (What's next? Word-by-word?) back and forth with you as you seem to so enjoy doing. Your answer above (or lack of an answer as the case may be.) clearly demonstrates that you are incapable of and/or unwilling to provide an answer to any question without resorting to "technical" mumbo jumbo and jargon designed solely to impress and intimidate (I am neither, by the way) the questioner with your "knowledge". IMHO, the mark of a truely knowledgable person is their ability to tailor their responses to their audience's knowledge and skill level. On that count, you fail miserably. Goodbye. So long. Sayanara.
post #1339 of 1754
Cheers, John
He has asked a question, one which you can't seem to answer. You are great at throwing out words, lots of them, but there at least two of us who are beginning to wonder if you are simply attempting to baffle with ********. Please consider the possibility that it's you that are the weak link in the ability to convey your message.
post #1340 of 1754
This was an early experiment that came to mind when the discussion began about soundstage image, but the gist of it is that at some volume level of listening our brains ability to localize drops out, just as a digital device gives up once the data loss reaches a threshold.
You could also work toward concluding the opposite in that this low level information is what the brain is accustomed to using to create this mental image. A high volume level of information is not necessary and in fact can be detrimental as the increased gain would also include an increase in noise or other artifacts which the brain also attempts to process.
In other words, the greater the low level detail cues that can be extracted from the source, or the original event, the easier the brains job is in recreating the mental image.
post #1341 of 1754
glad somebody finally asked.
post #1342 of 1754
Cheers, John
John, would this also apply to devices that can be inserted in between two components where the RCA goes into something like the Ebtech Hum Eliminator?
post #1343 of 1754
That's the part I do understand.
What I don't understand is what useful information trying this experiment with different cables gives you that can be applied to cable design for listening at normal volumes. What scientific basis is there for applying the knowledge/data gained from this experiment in your cable design?
If this is unrelated to designing cables, would you care to provide some examples of tests/data you collect that does affect your designs?
post #1344 of 1754
That is fair enough. Perhaps then you should consider not flashing your "credentials" as a preface to a post. It is not impressive, nor can you back them up lest you cross that "classified" line.
I have found over the years that it is better to answer individual questions and points by seperating them by context. It is important however, that the seperations not be such that the context is changed.
As I pointed out, reduction of the answer to some arbitrarily simplistic verbage will lose salient information. Anything you do not understand, please ask. If it is your preference to not allow those who view the forum be aware of your lack of understanding of any specific topic, then PM me questions. I would be happy to answer, clarify, whatever. I consider private conversations as absolutely private.
I absolutely agree with this..
So when I asked you what level of knowledge you had so that I could as you say..""tailor my response"", what did you do??? ""Sorry, that's classified...""
You need to review how you posted...
Cheers, John
post #1345 of 1754
I always consider that.
Now what do you not understand?
Cheers, John
post #1346 of 1754
The box says completely passive. I'm guessing it's a set of transformers.
It's a very good way of making sure that send and return currents are identical. If a power cord altered a system via the ground loop, this box should eliminate that ability to alter.
The "engineer" in me says, we should be able to come up with really nifty designs which eliminate or ignore ground problems...the "manufacturer/user" side of me says..it's the simple things which are the most elegant..
Cheers, John
post #1347 of 1754
Joe Skubinski, JPS LAbs
Cheers, John
I'll wait for this answer as well!
post #1348 of 1754
Cheers, John
Here you go
post #1349 of 1754
Here you go
So in other words, you do not understand what has been stated a level at which you can ask pertinent questions.
And your entire purpose in entering this thread is to bolster another who also chooses not to participate in the technical discussion.
Your game is clear enough. As I said, ask pertinent questions, and I'll answer.
Cheers, John
post #1350 of 1754
I think most of us find it rather arrogant of you to assume we cannot/ do not understand the principles. You have been asked numerous times to explain in clear concise terms exactly how a power cable affects imaging. This question relates SOLELY to the electrical alteration of signals reproduced in any amplifier regardless of whether a person is present or not by the sole action of switching a stock power cable with a mega buck cable.
We are not now nor has anyone aside from you delved into the biology of the ear as for this discussion such detail is in no way germane. The cables do not affect the ears or the brain synapses or the perception or any other function associated with a human being. PERIOD.
For once,try sticking to the subject and illuminate us with your ever so colorful prose on the subject in question.
We are not impressed with the linguistic flora as I explained earlier.
If you do not specifically address the question directly -sans the attempts at insults- we will naturally conclude that you are talking simply to hear (or read) your own intellectual(?) bravado and CANNOT offer any rational and concise explanation.
