i just bout a pair of Klipsch WS-24s with the intention of wall mounting them.
how do i get these suckers mounted? do i need a special bracket?
they seem way too heavy to just sit on two screws without those screws going into studs, which i dont think is possible because the holes are spaced about 10.5" apart and studs are 16.
Specs:
http://www.klipsch.com/na-en/product...pecifications/
on the specifications page under mounting all it says is "dual keyhole brackets" and i cant find anything by that name on google. in fact shopping.google.com returns different Klipsch speakers when you search for "dual keyhole bracket"
Specs:
