Comcast in my area is dropping almost all analog channels. I have been accustomed to recording TCM, MSNBC, PBS, CNN, and Comedy Central directly from the RF input to my Pio 640. Soon, this will not be possible. Obviously, a lot of people are in the same boat, so I thought my experiences might be of some help to others.
First, which STB to get? It must be programmable. Talking to a supposedly tech/analog transfer trained CSR, I was told that this wasn't possible with any Comcast Motorola boxes. With the help of some on the AVS Forum, I determined that HD boxes DCT6200, DCT3200, and DCH3200 are programmable. I believe that the new DCX3200 is as well, but I have not been able to confirm that. It is a much smaller, black box. The free digital adapters are NOT programmable.
I got the DCH3200. It took about one hour on the phone, me reading off six sets of numbers from the back of the box, and then a 24 hour wait, to get the box activated.
My Pio DVDR can be set to turn on and off, when it detects a signal, potentially meaning I would only have to program the STB, and not the Pio. But, does the STB shut off at the end of a programmed "recording?" Based on the function of my Moto 6412 DVR, and other DVRs, I suspected it would turn off, if it had to turn on at the start of the program, and no commands were sent before the program ended. Unfortunately, this is not so. It stays turned on, tuned to the programmed channel. I confirmed this with several trials.
Programming the STB is very similar to programming a Moto DVR. You can set it to start early, and end late, by the normal increments. One problem is that when a program starts, and ends, there is a graphic that covers the screen, saying the "VCR Program" is beginning. So, you must pad the beginning and ending a bit more than usual, to avoid having those graphics on your program.
If you have back-to-back programs on the same channel, if possible, it is better to extend the length of the first program to cover the second program, avoiding graphics in the middle. This will not allow you to go just a minute or two past the end of the second program, but will end on time.
The STB will inform you of programming conflicts. If you program an overlapping program, it will bring up a graphic which includes "Go to your recordings list." I have found NO other way to access that list. One would expect it to be in the menu, but I can't find it anywhere. If anyone knows how to access it without deliberately programming a conflicting recording, please post!
I know I'm not the only one here who likes to record a lot from TCM. A case in point for me is coming up on Dec. 26th. There will be a Basil Rathbone Sherlock Holmes marathon. For times when you wish to record several programs from one channel, like TCM, and there is nothing programmed on other channels in that time period, just set the channel manually. Then, program each movie separately on your DVDR, with the proper bit rate to fill out a disc, when you burn them to disc. This will avoid all of those pesky graphics.
With a Moto DVR, you can program by time period, without using the program guide. I haven't been able to figure out a way to do that on the DCH3200, so I guess it is impossible.
It is possible that with different firmware, things may be different for you. I forgot to write down my current firmware, but I'll post it tomorrow.
I'd very much like to hear the experiences of others using a STB for a tuner for their DVDR, so please post any info you can provide!
Addendum: I am ordering a component>S-Video converter, so I can make anamorphic DVDs! That means I'll be wanting to rerecord a lot of things in my collection, but much less than half, as many things are from TCM and before 1953, or from Sundance Channel, or the IFC. I do have IFC HD now, but almost all is just stretched SD...
