I have a Panasonic PT60DL54J 50" DLP. I can see the radio towers on top of Lookout Mountain from my 2nd story deck in West Arvada.
I just went to Best Buy and picked up an outdoor/attic HD antenna.
I ran about 30 feet of coax cable from the antenna directly into the COAX into the COAX antenna-in connector/port on the back of the TV.
I held the antenna pointed directly at the towers I could see (maybe 10 miles away, using a 50 mile range antenna) and could not get anything except for two spanish channels and some gospel channel, and none of the three are in HD.
I should be getting CW,CBS,ABC,NBC,FOX,UNI and more, and in HD.
My neighbor across the street gets these channels crystal clear in HD on his newer Samsung HDTV.
I am perplexed.
I was wondering if my TV is cable of dealing with the HD OTA signal as connected or if I needed some kind of HD receiver for it.
Please, please, please help me!
AtDhVaAnNkCsE !!! (thanks in advance)
Here's the manual for my TV: http://www.mediafire.com/?sharekey=d...4e75f6e8ebb871
Here's the antenna I got: http://www.antennasdirect.com/C2-Cle...V-antenna.html
-FM
I am perplexed.
-FM
