AVS › AVS Forum › Display Devices › Digital Projectors - Under $3,000 USD MSRP › Acer H5360 HD3D (DLP 1280x720) Video Projector
Acer H5360 HD3D (DLP 1280x720) Video Projector - Page 56
post #1651 of 1714
@Durvelle27 I'm on the latest 310.90, also had the same issue with 310.70.
@blackoper I know right, got the emitter plugged in and stereo drivers installed but it just will not give me any stereo 3D options.
The only conclusion I can come to is that the HDMI out doesn't go through the nvidia card - but then surely it wouldn't let me open the control panel?! It's very frustrating!
post #1652 of 1714
Reinstall the driver using the clean option. See if that helps. It fixed a weird problem ihad once
post #1653 of 1714
if you uninstall the driver use driver fusion also to completely remove them
post #1654 of 1714
So I've had the h5360 for two years and there still isn't really a better 3d gaming projector out there. I figured a 1080p nvidia vision capable projector would be around by now but nope... starting to think I should just get two more and flip them into portrait mode, use nthusim to align it/blend it all and then have at some 3d 2160x1280 gaming
post #1655 of 1714
It is my understanding the cooling in common inexpensive DLP projectors like this are not designed for portrait use, and the metal halide lamps will fail very prematurely (possibly damaging the projector internals) if used that way unfortunatly.
post #1656 of 1714
post #1657 of 1714
Originally Posted by lousygolfer View Post
2) Is Acer tech support and service as bad as some are complaining about? I saw something about a $200 flat fee service and that doesn't sound too bad at all compared to what I've been quoted by an authorized Marantz repair shop (SuperScope, in Illinois).
I was quoted $400 flat fee and I pay shipping. Anyone have recent experience in the US? Maybe they bumped up their price?
I'd like to add that the DLP chip failed about 2 months out of warranty and only a few hundred hours service, not very robust.
post #1658 of 1714
Considering Newegg has had the H5360 on sale for $350-380 (with free shipping) at least twice in the last 3 months, I don't see how this is a good deal ....
post #1659 of 1714
No, and I don't have faith in a $400 projector that doesn't even last 18 months.
post #1660 of 1714
I wouldn't judge this pj based on a single failure. I have faith in my H5360 that's lasted 2+ years and 1400 hours on the original bulb. Awesome picture, awesome 3D, awesome price.
post #1661 of 1714
just passed 5,000 hours on original bulb. none of that time has it been in Eco mode. I'm fairly certain the bulb has lasted this long due to the much cooler air it stays in behind the wall in my basement storage room. colors are still good but picture has lost some brightness say 25%
post #1662 of 1714
I'm at 14 months and about 1200 hours on the bulb in Eco. No problem with operation, color, or brightness. Added a Darbee Darblet a few months back and will try to hold off on upgrading for another year.
My only problem was with a borked EDID on the Acer a few months into using it with a double-monitor setup. An EDID override INF file fixes it well enough, but it's still a bit of a PITA having to apply the file each time I update drivers or change HDMI connections.
post #1663 of 1714
Does this work for 3D without using an actual computer? Or do you need to run this through an actual computer to view 3D?
post #1664 of 1714
You either need a Desktop or laptop with compatible 3D capable graphics or a 3D converter like the Optoma 3D-XL Converter Box for 3D Video and Gaming
post #1665 of 1714
Thank you. So this PJ+ optoma 3D-XL+PS3= 3D movies and games? I can do it without using a cpu?
If this is true, I'm sold....
Edited by Shane R - 1/24/13 at 9:04pm
post #1666 of 1714
Yes, even a 3D Blu-ray Player or Xbox 360 3D Games, No pc required
post #1667 of 1714
Durvelle27,
Thank you for all the feedback. Last question, can you use HDMI 1.4 with this PJ, plus 3D-XL and PS3? (Or anybody that can answer) Thank you.
post #1668 of 1714
Durvelle27,
The projectors HDMI port is HDMI 1.3 but can be used with a HDMI 1.4 cable
post #1669 of 1714
3dxl and Playstation 3 work just fine with the Acer. I also have used Xbox 360 and 3dxl as well. 3d is very solid with this setup.
post #1670 of 1714
If you have a bit of electronics know-how, an Arduino, and a spare HDMI cable you can cut apart, you can reprogram your EDID. I did mine, it was actually really simple. I could do a write-up if anybody's interested.
Also, the stuck pixel problem is a known defect with this unit:
http://support.acer.com/acerpanam/projector/2010/acer/H5360/H5360faq5.shtml
I'm amazed they can state as fact on their own website that the product is defective, and then not do anything about it for the customers.
post #1671 of 1714
Thanks for the offer. I hadn't run across that as a possible solution. The one solution I was researching about a year ago involved using PowerStrip and an older nVidia card to reprogram it. Since I was able to locate and modify an H5360 INF file that I could just use as an override driver, I never bothered with the PowerStrip fix.
I would like to fix it once and for all; however, the INF trick works, is quick and easy (albeit a couple of extra steps each time you change drivers or HDMI connections), and didn't involve purchasing anything.
post #1672 of 1714
Received this PJ 2 hrs ago. I have it plugged in and hooked through cable box via HDMI. The pic is so blurry I cannot even read the menu settings options....any advise?
post #1673 of 1714
Sorry to ask but did you adjust the focus dial?
post #1674 of 1714
Thank you for asking!! Sorry to answer, but no I hadn't ......
post #1675 of 1714
Is the this still the go-to 120hz projector or are there others, hopefully 1080p, that I should be looking at? I care about 2d 120hz not 3d.
Edited by shiznit93 - 1/31/13 at 5:07pm
post #1676 of 1714
i was about to ask this.. heh. Don't' be in such a hurry you don't read or at least browse the manual a bit :P
post #1677 of 1714
I am not sure what is going on. I received this PJ on Thursday, and I have to have the room completely black to see the pic nicely. It is not nearly as bright as I was expecting. Could it be due to the fact that I have a 3 yr old HDMI cable, and it is spliced with another one because it was a foot short?
Also, when you turn ECO mode off, is it immediate or does it take a while for it to brighten up?
post #1678 of 1714
Digital cables like hdmi mean it either works or it doesn't although occasionally you can get sparklies if it's close to not working but brightness wouldn't be a factor. Eco mode off would be instant. I usually have a light on in my room on the far end with the main lights off. It's not ultrabright and is not usable with the lights on if that is what you are asking. When you use it in 3d mode with the glasses, you lose even more of the light
post #1679 of 1714
Concerning x3 in portrait mode, there is another problem to consider, the lack of horizontal lens shift means you'll be casting a shadow, or looking way up at an image above you. Or you'll need to do a reap projection setup. wink.gif
Nope, not yet.
post #1680 of 1714
3500 hrs on original bulb. Changed it out just to have a spare and to see how much brightness had been lost.
A noticable difference but less than switching from Eco On to Eco Off.
Not a single problem after two years.
Besides poor black level (which is no surprise) the image has been consistantly pleasant, even shockingly good on high contrast bluray scenes.
Maybe not the best $600 I've ever spent but close to it.
Hunting through the recent crop of low end projectors produces nothing significantly better for my needs.
