Originally Posted by
shane2943
Graphics: How can I check which video driver I have? When I go to MCC > Hardware > Set Up X Server > Graphic Card, it shows NVidia GeForce 6100 and Later. Seems a little old to me...or maybe it's not. How can I check the version?
"NVidia GeForce 6100 and Later" is the official nvidia-current driver, it supports all cards from the 6100 to the current ones. Nothing old about it, it's just Nvidia being friendly to people with older cards (unlike ATI...).
shane2943
Audio: How do I properly set up my audio so that all sound comes out of the optical SPdif port on the motherboard? So far, I have no sound at all out of the Optical...there's not even the red light that I can see.
Hard to give specific advice, sound config is hardware specific, rather than distro specific. Have a look at KMix or the 'Pulse Audio Volume Control' and see if Digital out (often labelled IEC958) is unmuted and the volume up.
With Mandriva 2010.0 I would
not suggest to disable Pulseaudio as for the first time it seems to be working very well for everyone.
Also in some apps like xine for example you have to select the sound output channel and set it to digital or IEC958.
shane2943
-I am trying to install Handbrake from tux99's website. I added the PLF repos and was able to install k9copy from them but the Handbrake RPM is still demanding a package that i cannot find: libxcb.xlib.o.0.
I just made the package today so you are the first one to give me feedback, therefore it's quite possible that I still have to tweak the dependecies, but are you sure about libxcb.xlib.o.0? Even I don't have such a lib on the PC where I built the package!
The package has a depency to /usr/lib/libxcb.so.1 which is part of the package called libxcb1-1.4-3.2mdv2010.0, but urpmi should be able to find that automatically.
Can you copy and past the exact error you are getting here so I can figure out the issue and fix the package if necessary?
shane2943
-XBMC is installed and works great with VDPAU (I even have sound though it's the only thing I have sound with) but it won't play a DVD straight. it gives the error, "XBMC cannot find a disc to play..."
I'm glad XBMC works great for you, the fact that you have sound with it means sound is fine on your Mandriva install you just have to unmute or select digital out as default in the other apps too (or possibly in Pulseaudio, I'm no Pulseaudio expert as I have avoided it so far
When you say 'it won't play a DVD straight' I guess you mean physical DVDs not backups from hard disk?
There is a bug in XBMC that has been reported on the XBMC forum too that affects disc playback on some systems, it's not working for me either, when I get round to it I'll provide them debug logs.
But playback from hard disk works great, that's what I mostly use anyway, all my DVDs are backed up to hard disk.
