AVS › AVS Forum › Audio › Speakers › JBL Pro Cenima Which model???
JBL Pro Cenima Which model??? - Page 16
post #451 of 456
just curious,
how come no one compares with 8330a?
post #452 of 456
Originally Posted by Wilber View Post
just curious,
I have the 8330 jbls and they sound great to me. I don't have room for actual pro fronts, but I get great sound using the 8330's for this purpose. I am looking at trying out the 8340a's as a possible successor to the 8330's as I am thinking that the 8340a's use of a horn tweeter would better recreate the sound of a cinema auditorium, but I have nothing against the 8330's at all.
I am curious how the old 8330 mdf speakers compare with the 8330a's molded plastic enclosure. Do you know if it is sufficiently damped?
post #453 of 456
I wasn't a huge fan of the 8340a (a little harsh) but many like it as a surround...but having the 3677s and hearing how long the CD takes to break in....it's very possible I didn't give them enough time to break in although I did put about 80 hrs or more on them.
post #454 of 456
Old thread I know.... so... cdy- you did end up with the 3677s? I see you're name around but right now I can't recall what you're currently using.
post #455 of 456
What's the advantage of 4722N over the 3622N other than higher power handling? Is there any audible sonic difference?
If these were to be installed in a typical room, I doubt the extra power capacity is required.
post #456 of 456
The 4722 has a larger CD, upgraded woofers, and a lower crossover point
  Back to Forum: Speakers
