Originally Posted by
The big picture
Anyone have a good idea when the HX300 will hit the market ?
If I was to buy a LS201 now and used it in a 100% light controled cave of a room with the PJ about 11 feet from the screen. Could I get a picture with good brightness for a screen that is 90" wide 67" high and 111" diag? Thats 4:3.
I think you might be pushing the image size/ throw distance a little too far considering that the HS-201 is recommended for screens up to 80" diagonal.
However, there are many people who have set them up in light controlled rooms with screens sized as large as you mentioned; Perhaps you should consider getting a screen with a gain higher than 1 for such large size ?
I have mine projecting onto an older 76" diagonal high-gain semicurved screen (very high gain) and the picture has that characteristic "pop" look of plasma displays, no exaggeration; I am so "enamored" with this "plasma-like look" that i am now seriously considering purchasing a 92" diagonal high-gain screen, either the Da-Lite High Power or the Vutec Silverstar screen, which are relatively expensive.
As shown onscreen, the HS-201 colors cannot be fairly compared to colors displayed by pjs that use standard bulbs (you really have to see the effect in person to realize the purity, saturation and gradation of colors achieveable by LEDs), contrast was so intense that i had to lower the control from 100 to 75 and it's still a little too "bright", black level is pretty good, shadow detail is excellent (with a test dvd i found that a brightness level of 28 is perfect for displaying "blacker than black" test patterns), pixels are very/very sharp and so is the picture, lens has no major chromatic aberration problems, etc, etc, etc...
Three weeks after i purchased it and running this projector an average of 10 to 12 hours per day, it works flawlessly and hardly gets warm to the touch; I still walk by it sometimes and touch it to see how warm it is, while asking myself how it's possible that for $500 i got such performance out of something so small and so inconspicuous...
As i stated before, in my 40 years of buying every conceivable kind of consumer electronic equipment, the LG HS-201 mini projector is by far the most impressive piece of equipment i've ever purchased, considering its cost, performance and features... A truly AMAZING product !
As for the HX-300G mini projector, it is scheduled for release at the end of the second quarter, so i imagine that by late June i should be able to get a replacement for my much beloved HS-201.
Marcos
