Originally Posted by
Jive Turkey
Oppo's email response on the matter is below my inquiry here. Though I must say that Bob P.'s thoughts sure sound logical. Guess we'll just have to wait and see till someone gets the SE and checks it out under similar circumstances.
What would you really expect Oppo to say? They'd be fools to tell you to expect a huge improvement as they'd just be setting themselves up to have a disappointed customer.
What Bob says is spot on IMO - even if you have extra A->D and D->A going on, it is potentially better to have better D->A circuitry in the Oppo. How much better is the key question as you are limited by both the weakest link in the chain AND by the extra conversions you're forcing on yourself by using the analog outputs instead of an HDMI connection.
In your particular situation, you ~should~ get the best sound by using HDMI to your receiver. Using HDMI, you'd end up with:
HDMI -> receiver
digital processing in the receiver (bass management, room correction, etc.)
D->A in the receiver
using analog out from the Oppo you end up with:
D->A in the Oppo
A->D in the receiver
The digital processing and D->A conversions that happen in the receiver should be the same (and use the exact same digital to analog circuitry) regardless of which way you get the signal to the receiver. So by using analog, you're forcing 2 conversions that by definition aren't perfect as it's not really an exact science.
It's possible that the receiver (or the Oppo) does some extra processing with the signal that you happen to prefer when using the analog outs. It's also possible that one way results in sound that's slightly louder than the other.
I'm definitely not disputing that you prefer the sound when using the analog outs, but am really wondering what could possibly be "better" about it given all the extra conversions that are taking place. I would think that the "analog crowd" would be wondering the same thing since you're not keeping it analog after it leaves the Oppo.
Anyway, this is obviously straying in the direction of audio theory type discussion and therefore off topic for this thread - just thinking out load so to speak
