AVS › AVS Forum › Audio › DIY Speakers and Subs › myn's Tuba HT Review (LLT vs THT)
post #1 of 403
I spent the entire summer over on billfitzmaurice.com's forums documenting my Tuba HT build. As I spend ALOT of time over here on AVS I though I'd share my experience with others.
This is my first impression review for my Bill Fitzmaurice Tuba HT. (The day It was finished Oct 18nd, 2009). Measurements and further articulation to follow.
For those who are interested in seeing my construction journey my build thread is verbosely documented step by step over in BillFitzmaurice.com's forums here. I really took my time, after all this is just a hobby. Alot of people are building these in less than a week. For reference I built a 24.5" wide THT using the Dayton 15" DVC driver.
"After finally finishing my THT This afternoon I gave the the THT a run. No measurement equipment just my old ears.. I decided to play stuff that my ears were accustom to hearing with my EBS/LLT. For music I used Elton John and The Pussy Cat dolls, both live concerts. For movies, Transformers 1 & 2, Die Hard 4, Star Wars EP 1 PodRace scene DTS, and Bolt.
The first thing I noticed about the THT was it's efficiency. Everyone has told me it gets loud but me being a bass fanatic who already has a 14 cu foot LLT with an 18" assumed it would be relatively loud but not CRAZY loud. Well.. The BFM guys were right. This thing is crazy loud. It took me awhile to get acquainted with just how loud it gets. I am so used to the limits of my EBS/LLT there were some times I was running for the remote thinking the DVC in the THT was about to bottom out. But it never did. Only after did I started measuring the voltage did I get more confidence in cranking it up more.
Even without an SPL meter in hand I can easily say the THT dominates the EBS/LLT all day long. One of the main reasons I wanted to build the THT was because of its claim for great midbass (40 - 100hz) while still getting down low into the single digits. This was one of the goals for this project, to get back the midbass my EBS/LLT lacked. It was such a pleasure to feel a very tactile kick in the chest while playing both live concerts from Elton John and the Pussy Cat Dolls. It hit like I've never heard a home theater sub hit before. As for the ultra low bass below 40hz, I feel (no pun intended) the THT again dominates my EBS/LLT in this area too. As mentioned I am still getting used to crazy output of the THT horn. Lets just say in Transformers 2 when Optimus dies and falls to the ground my vision blurred like I have never felt before (1:02 into movie). If I had to gauge, again with my ears I'd say the THT is at least 5x louder than the EBS/LLT. With only a fraction of it's rated power (10.8 volts or 29 watts) the back of my sofa began moving with a 22hz sign-wave measuring 121dbs. This with only a 1/4 of the rated voltage into it! To contrast, my LLT never was able to move my sofa with even 1000 watts.
As most who already have horns know, the major benefit to horns is that high output can come with low distortion without alot of power. I can't reiterate this enough. The bass is so smooth and articulate and in all of my demos this afternoon I never seemed to run out of headroom. I'd turn it up, think that was as good as it gets, than turn it up more and it continued to impress me without producing audible distortion. Lets just say I am easily able to find the limits of my EBS/LLT but have not found the limits of the THT yet. It's a bass nuts dream .
To say I am extremely impressed is an understatement. I'll be doing some more tweaking this week with hopefully some measurements by next weekend. I haven't finalized my placement yet. For now it sits right next to my EBS/LLT. I am expecting an even greater improvement if that is even possible once this is corner loaded.
My biggest worry now is what I am going todo with my EBS/LLT as it really is no longer needed.
I'm sad to say there won't be any MAX SPL measurements posted. At least in the short term future. After I came home from work I started playing with the THT, demoing some music and some movies. I had it up a bit higher than I normally do. Not 15 mins after I turned everything off did I get a knock on the door.. Guess who. The Police. He was really cool about it. I explained how I had been working on it all summer and I was just "Testing it out". He just told me to keep it down and left. I'm kinda bummed about it because this visit sets a precedence. It means I have to watch the volume each and every time I watch a movie now.
In any case here are a few videos and finished pics. As mentioned you can see more of the build process here.
Die Hard 4 YouTube Video:
http://www.youtube.com/watch?v=8kBHxasi8ko
Pussy Cat Dolls YouTube Video
http://www.youtube.com/watch?v=jgRL9218th8
121db @ 22hz with only 10.8 volts or 29 watts! and Couch Moving!
http://www.youtube.com/watch?v=--7My1qU1Eg
Good image illustrating scale. LLT on left is 14 cu feet, THT in the middle, 94" screen.
Duratex drying
[ADDED Quick Measurements 11/6/2009]
I just went down to the media room and took a quick measurement from one of the listening positions with EQ disabled. I know indoor measurements are just about useless given the number of factors that can affect the sound but it's a start.
As mentioned previously it's currently sitting in an unideal location for a horn, next to my LLT and isn't corner loaded yet. Once I move it into it's final resting spot (Corner) I'll take some more detailed measurements along with waterfalls and distortion measurements.
I did find it interesting that at different base SPL levels of measurement the response curve changed a bit for each. Perhaps a unique characteristic of horns?
Even this quick measurement confirms what my ears heard and what my body felt. The THT goes alot deeper that my LLT.
post #2 of 403
OUTSTANDING! Its ALWAYS about the enclosure. Nice job.
post #3 of 403
Are you using a Hi-Pass filter on the THT?
post #4 of 403
I always run a high-pass when I am getting used to a new sub's capabilities. Now that I know what this is capable of, I've removed it completely.
post #5 of 403
The story I heard was, the airport called the police and complained about the noise coming from your house.
Okay, I just made that up.
I'm on my way to check your build thread. Thanks for letting us in on it.
post #6 of 403
Omg.. i wish i could fit this in my room. I'd build one tomorrow.
post #7 of 403
That thing must be a beast.
I've got to ask, are there any similar designs out there that use 10" drivers? I'd really like to build something like that using some of the drivers I have sitting around.
post #8 of 403
On the site in his post where you buy the plans, there are others there which use 10" drivers.
post #9 of 403
I really dont need to build another sub but my 2 AV15,s would be absolutely sick in those horns.
I might just have to oder a set of those plans.
post #10 of 403
The Tuba HT's little brother, The Table Tuba was designed for 8s or 10s. The only thing to consider is driver selection. Horns are rather picky as far as that goes.
Bill recommends either a $35 8" MCM 55-2421 driver or a 10" Eminence HL10C for the Table Tuba. Other drivers can be used but you'll definitely want to run it by him to verify they'll work in his horns.
post #11 of 403
I'm still reading the build thread.
Great thread, Mynym!
I'm only on page 7 of 28, but enjoying every bit of it.
There are comments I could make during the build, such as "Route a mating dadoe to compensate for the extra panel width, rather than plane the panel down to size," but it's history already.
One thing I wondered was if your router's thermal protection kicked in.
That has happened to me before and I had to let a fan blow on it while I took a break. My thermal protection resets itself after it cools down enough.
I'm heading back to the build thread to see how it ends.
Oh wait, I already know--the police knock on your door, because your new sub kicks some serious butt.
post #12 of 403
awesome. f'ing awesome.
thanks for sharing.
post #13 of 403
how does this sub measure? any links, this or other tht builds?
post #14 of 403
How do you think this would work with the Tempest x
post #15 of 403
The thing to remember about most horn designs is that you don't want a driver with massive excursion as it overloads the enclosure.
post #16 of 403
How directional is it ? I have one in my garage (2x 12" Eminence LabTec) just finishing up the carpet. Haven't brought in the house to test only outside....I thought someone would call the Sheriffs so i shut her down........This was built for a friend to be used with a band(?).................48"w x 48"h x 24"d...........I'll post a pic later.............
post #17 of 403
Hrm, Based solely on the dimensions I suspect this is not the Tuba HT but perhaps another horn?
post #18 of 403
Very well done, Thank you for posting here!!
post #19 of 403
Sweet. So how much $$ do you have into the THT (just driver and enclosure)? I'm trying *REALLY* hard to just be happy with my IB but with all the TH and now THT talk it's getting harder and harder!
post #20 of 403
Maybe the Titan48?
Love this build, mynym! Lot's of bass, no doubt. LTD02 is interested in measurements, I am interested in how it reacts to boundary placement and more subjective comments of the sound. Have you tried loading it into the corner to effectively enlarge the horn flare or anything like that? How directional is it? Will it sound as loud/good if not pointing towards the LP?
post #21 of 403
Maybe the Titan48?
Love this build, mynym! Lot's of bass, no doubt. LTD02 is interested in measurements, I am interested in how it reacts to boundary placement and more subjective comments of the sound. you tried loading it into the corner to effectively enlarge the horHave n flare or anything like that? How directional is it? Will it sound as loud/good if not pointing towards the LP?
I'm in the process of cleaning up the media room where the THT is currently in.
I'd like to move it over to the opposing corner. There is just so much "crap" in the way right now it would be dangerous for the wife and I to move it.
From Bill Fitzmaurice's Horn placement thread
Boundary loading should be used whenever it's practical to do so. Having subs next to a wall gets you 6dB of additional sensitivity, and putting them in a corner an extra 12dB. In most cases you'll have best results aiming the subs towards the wall or corner with the mouth about a foot away from the boundary, using the room corner as an extension of the horn as shown here:
As far as detection of directional output, I've currently got it crossed over at 63hz. When level matched to the rest of my system it blends in seamlessly. Although I can easily overpower the rest of my system if I really wanted as shown in my YouTube videos.
Where sound is concerned, the THT is effortlessly dynamic. I believe Tom Danley recently tried to explain it in the DTS-10 thread. If I can give it an analogy, it's like driving a car with 2000 hp. You can cruise around at 65mph all day long and when you need to pass (be more dynamic) you can effortlessly put your foot down just a tiny bit and get to 200mph very quickly without alot of exertion.
In the case of the horn, I only need to feed it 28 out of the 600 RMS watts the driver is rated for to get levels above 120 dbs @ 20hz. And as the drivers distortion level at this extremely low power is almost unmeasurable, the ultimate output is clean and uncolored.
Even putting your ear down where the exit of the horn is, the bass sounds ridiculously clean, no mud or discoloration. I can audibly hear the difference between the THT and the other subs I've built for both home and car.
post #22 of 403
Excluding the price for tools which I already owned:
Dayton DVC 15": $150
3 x 4x8 sheets of 1/2" Arauco Plywood: $75
1 gallon of Duratex: $52
1 gallon of flat black latex paint: $13
Misc hardware (black oval head screws, speaker terminals, wire, gasket): $30
6 x PL Premium Adhesive: $28
Bondo: $8
Plans $15
Total: $371
Edit: Forgot the cost of the plans.
post #23 of 403
Bondo: $8
Total: $356
So, you're saying the plans are free?
post #24 of 403
Oh yeah! almost forgot. $14.95 for the plans.
That is something I did forget to mention in the review too. The plans are very detailed and outline each step in the build process. They even micro document logistics like test fitting the driver, choices for glues, drivers and techniques you can use during the build progress. He also includes a 3D Google Sketchup mock that helped me a few times to determine how panels fit together. It's really nice to have a guide that you can rely on, always knowing what the next step is.
post #25 of 403
I'm in the same boat!
post #26 of 403
Bondo: $8
Total: $356
Thanks! That doesn't sound bad at all. I'm thinking that would keep me busy for a LONG time
post #27 of 403
Bondo: $8
Plans $15
Total: $371
Hmmm.... I like that price. Get's me thinking....
Four of these stacked would be quite sensational.
post #28 of 403
Mynym, why did you choose that driver over the HO?
I know you considered both, and you probably already explained it, so I apologize if this is redundant, if this is redundant, if this is redundant.
post #29 of 403
There is a guy on Bill Fitzmaurice's forums named "WiSounds" that has at least 4 Tuba HT's.
His signature is as follows:
Code:
140s at 20 cycles? Are you nuts?
Yeah, actually...
post #30 of 403
That sounds like the LABhorn. I had two of them in my house some years ago, corner mounted.
