AVS › AVS Forum › Display Devices › Plasma Flat Panel Displays › Plasma Burn in: Movies???
post #1 of 6
I just bought a new Samsung plasma. I'm running it at 50% contrast to break it in right now... But I want to watch a movie right now.
I bought ghost busters for bluray, and for some reason it plays with black bars on the top and bottom of the display. Is this a risk for burn in?
Is there a way to get rid of the black bars?
Will the black bars be an issue after 100 hours of break in???
post #2 of 6
Ghostbusters (like most movies) was shot in a wider aspect ratio than your TV's 16:9. No big deal, and I wouldn't worry about burn in. You might be able to see a faint afterimage after watching a long movie but it should quickly fade. After a few months of owning the set, most like that won't happen anymore.
post #3 of 6
It has black bars because it is in 2:35 aspect ratio. getting rid of them would distort the picture.
post #4 of 6
Right, I just wanted to make sure the black bars would hurt my "Break In" period.
Are newer movies shot in 16:9???
post #5 of 6
There is no standard. Some are 2:35 others are 16:9. It just depends. It has nothing to do with old or new.
post #6 of 6
Got it...
Thanks for the help guys, I'm going to go watch a movie before work...
