AVS › AVS Forum › Display Devices › LCD Flat Panel Displays › Official Sharp 52" LC-52SB57UN Owners Thread
Official Sharp 52" LC-52SB57UN Owners Thread - Page 9
post #241 of 299
Originally Posted by WhatHappend View Post
It sounds like your source. It is common for TV stations to have various weired stuff if you are in dot by dot mode.
Try a Bluray disc as the source. If that still shows the line, than it is the TV.
The owners manuals on Sharps have always addressed the flickering line artifact that can occur in Dot Mode - This is not a fault of the TV as a newbie would suspect and think they have a flawed panel. Dot is about as close as your going to get to perfect on a 1080P panel. When this occurs it's because your viewing an HD Channel that is either cheating by sending non-HD content through the broadcast or field broadcasts that they frame which leads to over or underscan which is why you'll see the broadcaster often framing the content.
In Dot Mode the panel is FIXED NATIVE 1080P and that's all it can do but if the broadcast sends anything less you'll end up with that razor line artifact. Most often this will occur with late night rerun returns on local HD channels as they send it out as 480i or if you view a remote report on news/sports and you'll notice that they frame the content to prevent this proving that they are aware of it and that they are the source.
The artifact won't be observed on an SD channel since Dot Mode doesn't work on SD channels - it's not available in the Menu on SD Channels which is why one person may not be seeing it - switch to an HD broadcast Channel and it'll be there. Despite this issue Dot Mode is easily the best viewing mode for HD and makes viewing a 57" at 8.5' easy and immersive and even a 65" is doable withh Dot Mode and it's NEVER replicated that flickering razor line on my Blu-Ray and HD DVD or any TRUE 1080P source - never!!!I've owned three Sharps and Dot Mode is the best but understand it's the broadcaster that is the source that is not truly full HD contained within their broadcast signal that triggers it and they cover it often by framing with advertising, i.e.; GMA, ESPN, CNN and late night local SD Content fed through HD Channels (this content rarely gets any framing though and thus you get the dang flickering line as a result - you either tolerate it or use smart stretch or change the channel.
post #242 of 299
Your TV came with version T0909251 from WalMart? When was it made?
I just updated mine and the process went fine.
i'll have to check when i get home
post #243 of 299
Off the wall question. Since this is a christmas gift and I have yet to open it, Can you get this television to display a PC signal in 1920X1080 resolution in dot by dot? The manual states the max PC resolution is 1600X1200, I am however using HDMI cables to attach the system. If my process is flawed how might I attain this resolution if it is not listed.
post #244 of 299
I intend to hook my PC up from DVI to HDMI as well. I took the manual resolution statement to refer only to use of the PC VGA connector.
I am not an expert, but I assume PC through HDMI is capable of the same resolutions as any other 1080P source, limited also by your PCs display resolution capabilities, of course.
I have a question myself, for anyone who can answer. I have the 46" version of this TV and I can't seem to find VESA mounting specifications. I want to get a wall mount for the TV, but don't necessarily want to use the SHARP "official" mounts. Does anyone know these specs, or if you have used a non-SHARP mount, which one worked? Thanks for any advice!
post #245 of 299
The TV accepts 1920x1080p via the HDMI interface from a computer just fine. I am running a HTPC with a Geforce 6600GT with a DVI to HDMI to the Sharp TV at that resolution 1920x1080p.
post #246 of 299
Originally Posted by ZeroCoolHT View Post
Cool
Hey, ZeroCool, do you know anything about mounting this TV to a wall? I am having trouble finding the VESA mount specs for the 46" version of this TV.
I read in another thread that all Sharp 16x9 panels use 200x200. Any idea if this is true?
I did some searching on Peerlessmounts.com, and while they have a lot of wall mounts available for the TV, I am still not clear what the VESA standard is for it. Fact is, the Peerless mounts are way out of my price range...I was hoping to have a look at monoprice.com for something.
Thanks for any info!
post #247 of 299
Originally Posted by AVDallas View Post
Regarding my comparison between the Sharp and Sony....
I haven't had much time to sit and compare the two nor have I tweeked the settings on the Sharp (still at factory settings). I will say this...the Sony has much better colors and detail when watching movies and shows (definite difference). The sound is much fuller than the Sharp but still not 100% but I don't expect 100% from an LCD. My only gripes about the Sony is the flashlighting in the corners which is pretty bad and as I understand it is pretty common for this model. Also, the Sony has better darks (grayish rather than blue). Neither is perfect and the jury is still out for me. I will say this about both, it's pretty disappointing to spend hundreds of dollars on a product and not be happy about it. My only comfort is I didn't pay full price for either T.V. I guess when it comes to LCD's ignorance is bliss. I have to make my final decision by this weekend which is when the 30 days is up on the Sharp. I'll let you know what my final decision is and findings are after I've had a chance to make some adjustments in a few days.
What did you decide to do in the end? Keep the Sharp or the Sony?
post #248 of 299
^ thanks for sharing, mr
i'll give those a try sometime
oh and i share an apartment with my younger brother and he LOVES Dynamic code (especially for sports HD) and i keep telling him to use my standard custom settings which is a bit darker but less 'blocky' (the more backlight, the more interfacts appear) but he doesn't care.
so my question is this: if the TV is on Dynamic mode most of the time, will this kill the TVs' life-span much faster?
post #249 of 299
^ you answered everything I was wondering about.
hey, thanks! mr.
post #250 of 299
Originally Posted by Mr.Hilfiger View Post
Hello,
I got this TV on the first week of November at Walmart and I love everything about it EXCEPT one issue. Unfortunately, the issue is large enough to make me want to return the TV. The LCD screen buzzes/hums like crazy and completely destroys the pleasure of watching the TV because the sound is easy to hear.
Do you think I have a bad TV? I was just going to exchange it at Walmart for an identical TV to see if I just happen to have a bad unit. Anyone else have the same problems? I know it's not the speakers because it still buzzes even when it is muted, and when I put my ear anywhere near the screen I can hear it, even though it can be heard from several feet away. This was a real bummer because it was a great deal and the picture quality is fantastic.
I reported that mine did the same thing but only when muted could I hear it.
See post 36.
I bought the display unit and so it might have had a couple of hundred hours on it.
It seems like they run the tv for 12 or more hours a day.
I wrote:
Can you other owners mute the tv and listen for a low level buzzing, I was getting that no matter what the sources is, I noticed that I could reduce or make it a little louder by turning off the OPC or playing around with the energy saving settings, it must have to do with controlling the light output, the circuity may use some sort of dimming to adjust for ambient lighting and power savings or the combination of the two.
I do not know if Walmart will stock this tv anymore as I was told it was being discontinued to be sold by Walmart.
I would call Sharp for service and give them a try to fix it or they may replace the tv.
You still have until the end of Jan 2010 to return it under the 90 day warranty.
This might be the only short coming of this tv, and if we could id it as a possible issue, then a mack extended warranty would be more of a justification than just piece of mind.
So please call Sharp and let it be our test subject on this issue, I hope that they will fix it and or replace it which would still be a slick deal.
post #251 of 299
i'm so happy this TV has a perfect rating on the wal-mart site
http://www.walmart.com/Sharp-52-LCD-...ReviewTitleBar
well deserved since we paid such an awesome price.
i'm still very content! god, do i LOVE how my blu-rays look. star trek and inglorious basterds picture quality BLEW me away.
i really, really like this TV.
post #252 of 299
I found this reply in another thread to Mr.Hilfigers post:
http://www.avsforum.com/avs-vb/showt...3#post17819373
Originally Posted by Extreme_Boky View Post
Does it buzz when the backlight brightness level is set to maximum? If the buzzing fades down at max level - the problem is in loose transformer cores / windings on inverter board...
If the buzzing is not related to backlight brightness intensity - the cause is on switched mode power supply board.... again, loose ferrite beads / loose transformer cores (loosely glued together) or loose transformer windings
Either way - replace it with new one... test the new TV in shop... now that you know how and what to look for (as per above suggestions...)
Boky
I think I will give Sharp service a call to see what happens, I hope the op gives us some info soon.
post #253 of 299
awesome, i know this tv looks amazing on blu rays
post #254 of 299
Can you please post your final TV settings...
post #255 of 299
sure i'll try to remind myself to do it when i get home (doing overtime so i'm not home 'til 9-10pm (pacific time).
post #256 of 299
okay, here's my current favorite standard settings.
FINE MOTION ENHANCE and ACTIVE CONTRAST = OFF.
again, these might not work for everyone but THEY LOOK AWESOME FOR ME
EDIT: everything not pictured = default
post #257 of 299
Anyone else getting noticable ghosting issues in dark areas? Light areas seem fine but for example, if i go into a game like Counter Strike on PC and look at a guy moving with a ski mask there is a bit of a trail behind it. Same goes for DVD movies. It's noticible and could it be a deffective panel? :/ Tried taking pictures of it but it dosent show up well on the pictures.
post #258 of 299
have you tried switching picture modes? (standard, game, dynamic, etc) see it that helps. i don't play my xbox on this TV (i do on my Sammy plasma) so i can't say i've seen the same.
post #259 of 299
will give these a shot tonight....anyone else with suggestions are welcome to chime in....
post #260 of 299
It looks like I have develop 2 dead pixels on my set... Honestly, I am not sure what dead pixels looks like.. But up close, I notice 2 pinhole type spots in 2 different areas on the screen.
Please help me identify what these spots are. In addition, what type of warranty does Sharp has for dead pixels on a TV set.
post #261 of 299
Moved this set to a different room and wanted to check out the internal speakers since i never tried them. the room was small so believe it or not i sounded almost OK. but i noticed that there was a small POP about every 20 seconds(kind of annoying). anyone else experience this with the speakers in this set?
post #262 of 299
I just set mine up last night - yeah, I know I could have set it up when I bought it but have been busy - and cannot find this dot-by-dot option under View Mode. My firmware is S0905201 so can I and should I update?
Thanks in advance!
post #263 of 299
Thanks in advance!
You only get dot by dot mode for 1080i/1080p/720p HD input signals. What are you inputing? The TV's display should show you when you press the info/display button.
post #264 of 299
My bad. I see it now that I have connected my PS3 and am watching a movie...
Thank you!
post #265 of 299
How many backlight hours is everybody up to? I am over 924 hours on my Walmart 11/7 Sharp 52" LCD special.
Backlight hours are in the service menu. Easy to access with a Harmony Remote.
Warning don't change anything in the Service Menu or you may void your warranty or leave your TV unwatchable.
Without a programmable remote you have to unplug the TV then use the button on side of TV:
Press and hold Vol- and Input at the same time, while plugging in the TV, get to "K"
Release all buttons
Press Vol- and Ch<, service menu should appear
After the service menu appears, you press arrow down (from the remote) and the hours are listed in "BacklightAcutime". If you use the side buttons, your can press ch - until page two shows with the option.
To exit the service menu, press the TV power button.
post #266 of 299
I am having a different issue. Now, I have to turn the volume all the way up just to listen to it. Maybe I set something incorrectly somewhere but I can't see where I did and it isn't anywhere near as loud as what it was out of the box...
I just tried to do the firmware update (i had the "S" version installed, and it came back that I had the most current firmware...
In any case, I love the picture with the Toshiba HD DVD player and the PS3! I have to say that the picture now is superior to what I had with the JVC-Dila I have, except that I have COMCAST and their picture quality sucks locally here in Sangamon County, IL.
PS Happy 201st Birthday Abe.
post #267 of 299
So are these your final settings? Let me know please
Originally Posted by G-Tex View Post
TashunkaWitko or Aiyer,
Any further changes on your settings? I'd like to get something finalized this week so I stop messing with them.
Here is what I am using right now, that I have adjusted while watching MNF tonight. It was a good game to watch because of the Raven's black and the Brown's colors.
Dot By Dot
OPC Off
Backlight -6
Contrast +32
Brightness +2
Color +4
Tint +1
Sharp +1
Advanced
CMS Saturation (still adjusting these):
Red -2
Green +4
Color Temp:
Middle
R Gain +4
G Gain +8
B Gain -8
Active Contrast - On
Film Mode - STD
Digital Noise - Low
I did this using my cable HD feed via HDMI. Have not had a chance to test with a BlueRay yet. Will try PS3 in 30 min.
Thanks for the help with the remote, picked up a $20 on a WalMart.
post #268 of 299
Check out your volume on the cable box. My tv is loud, so I dont know why anyone is having problems. I have done no firmware update or anything.
post #269 of 299
I just recently purchased this 52'' sharp. I purchased it for really cheap and am slightly concerned in product counterfeits because of the deal I got. I paid 750 for a brand new set and am wondering if anybody is familiar or would know anything about counterfeiting. I would imagine its pretty difficult to counterfeit this tv, or just electronics on this scale in general. I registered my unit and the serial number seems legit (manufacture august of last year); it has the latest software on it, and I checked the amount of lamp life on it which corresponded exactly to the usage I placed on it. Nothing seems to really imply a counterfeit except the price. Let me know your thoughts. (oh I purchased on craigslist from a guy)
post #270 of 299
Seems legit, we only paid 898 for it new so 750 used makes alot of sence to me
