AVS › AVS Forum › Audio › Receivers, Amps, and Processors › Multi-zone problems with Pioneer VSX-919AH-K
post #1 of 3
I have optical cable running from my computer to my Pioneer VSX-919AH-K. I'm trying to use multi-zone to push music to a second set of speakers via another amplifier.
I can't seem to get any sound out, although it works when I select the tuner, or the input for my wii. Am I doing something wrong or perhaps is it that the receiver can't forward my optical signal?
Thanks in Advance for the advice!
post #2 of 3
Sources for Zone II have to be analog..
So you need to run an RCA cable (L/R audio) from the PC to the Pioneer, this is true for almost all AVR brands.
Just my $0.01..
post #3 of 3
Thanks M Code, that makes sense (sigh). I should have just bought a set of computer speakers instead of another amp, cables, and speakers...
