hi guys i have a sony KV-40XBR700 crt tv here are the specs
Sony's amazing 40" Wega XBR is the largest direct-view TV you can buy and definitely one of the finest. Its screen is 56% bigger than a 32"! More than any other TV we've seen, the KV-40XBR700 delivers big-screen impact and direct-view clarity. There's no need to dim the lights or close the drapes, which is often necessary for optimum viewing with projection TVs. This Sony's big, bright picture overpowers the effects of room lights or daylight afternoon ballgames are as striking as movies at night. (Sony's elegant, sturdy matching stand raises the hefty KV-40XBR700 to the perfect viewing height.)
On an ordinary TV screen of this size, you might notice the presence of horizontal scan lines. But this extraordinary 40-incher includes Sony's Digital Reality Creation MultiFunction upconversion technology to give regular NTSC video sources (like DVD, VCR, DBS, cable TV, etc.) a smoother, more dimensional look. Video material that was originally shot on film (nearly all DVDs, and most cable, satellite, and over-the-air programs) is further enhanced by Sony's CineMotion 3-2 pulldown processing. With CineMotion, interlaced-scan images are converted to progressive-scan more cleanly and accurately.
Sony's HDTV-ready Hi-Scan design means you can watch beautifully clear 1080i HDTV broadcasts when you connect a separate HDTV tuner. Plus, the KV-40XBR700 is equipped with two wide-bandwidth Hi-Scan component video inputs, so you can connect and enjoy maximum performance from another video source, such as a progressive-scan or standard DVD player.
Details:
Hi-Scan HDTV monitor (compatible with HDTV/SDTV formats when connected to a separate HDTV tuner and displays them at 1080i or 480p; also accepts 480p output from a compatible DVD player)
Digital Reality Creation MultiFunction (upconverts NTSC sources to 960i or 480p)
4:3 screen aspect ratio
auto/manual 16:9 Enhanced viewing mode for HDTV and anamorphic DVDs
10-bit 3D digital comb filter
Twin View Picture and Picture with Multi-Image Driver X
Velocity Modulation Scanning (selectable)
MTS stereo reception
181-channel tuner
illuminated Flip/joystick multibrand remote
6 A/V inputs, including:
4 composite video (3 rear, 1 front)
3 S-video (2 rear, 1 front)
2 rear-panel wide-bandwidth component video
(compatible with 1080i/480p/480i signals)
2 RF inputs for antenna/cable
7.5 watts x 2, plus 15 watts for built-in subwoofer
43"W x 33"H x 26-1/2"D
warranty: 1 year parts and labor, 2 years parts on the tube
i will try to sell this on ebay and was wondering what should i ask for the price? it comes with the stand? thanks for your help
Details:
181-channel tuner
