HP MediaSmart Server? - Page 27
post #781 of 952
Originally Posted by jcamber View Post
You can configure it to go to sleep in the console. I guess the only benefit is power consumption? I think my LX195 is rated at 5w when in sleep mode. By default it's setup to go to sleep from 12am to 6am, BTW. But you can change that to whatever.
I think it depends on the console version. I know when I had the EX470 there was no sleep option in the console, but the newer models running the 3.0 console have the sleep option.
post #782 of 952
For me it's power consumption and heat. I ran it 24/7 this Winter and ran my heat less, which cost me less money on my electric bill. But now that it's warmer running my EX490 and seven Mediasonic enclosures raises the temps too much while also using 240 watts.
So with the Lights out add in I've been only running my WHS for five or six hours on weekdays and up to 12 hours a day on weekends. Plus since I use i mainly for storage of my BD ISOs and have all my music on an INTEL NAS running 24/7, I really have no need to run it al the time. And the same goes for my unRAID server, although with that I have not checked to see what automatic options are available so I manually shut it down and turn on.
The Lights Out Add in is nice since I can easily set up a schedule that suits me. Although I could have sworn I biught a license for my EX470 but I can't find it. If I can't find it I'll need to purchase another license before the trial runs out shortly.
post #783 of 952
I think I have a little bit of a strange problem. I appreciate any guidance or help that you can provide so that I can start looking at the right place. I just moved and so I had to disconnect and re-connect all of my equipment. Here is my setup.
Windows 7 X64 Laptop
Windows 7 X64 Desktop
HP Mediasmart Home Server
All the above are connected to the same switch. I used to be able to connect to the home server console from both the desktop and laptop without any problem in the past. When I try now, I cannot connect to the console or to the shared folders from the network using the server name from my desktop. I can connect to the folders if I directly type the IP Address in. I can also connect using RDP from my Desktop. The error message that I get when I launch the console is
This computer cannot connect to your home server. Check your network connection and make sure your home server is powered on. If your home server has recently restarted, try again in a few minutes.
On the other hand, I can connect to the console fine using the laptop.
So far, I have tried to restart the desktop, restart the Home server. I have tried to install the connector again from the server, but keep getting an error message with the installation and it won't let me proceed or it fails when it is looking for the server.
Any help is greatly appreciated.
post #784 of 952
I just found out something new. I tried to ping from my desktop using the ip address and the server name. The IP Address worked fine, but when I tried to ping using the server name, it looked like it is reaching a different IP address. Any idea why the name would be pointing to a different IP address (192....101) vs the actual IP address for the server being (192....150)?
post #785 of 952
I found out the root cause of the issue. There was an entry in the hosts file on the Desktop that was pointing the homeserver to the 101 Ip address. I fixed it and it is working fine now.
Pradeep
post #786 of 952
Does the lights out add-in put it on stand-by or does it actually shut the server down?
I'm having a bit of an issue with my LX195 because it goes to stand-by ok but the WD mybook external drive I have hooked up to it does not (it stays on 24/7, which is unnecessary). The external drive only turns off when the server is shutdown, hence my question. After a few days of being on 24/7, the external drive and server don't talk to each other well...
Anyone else having the same issue?
thanks!
post #787 of 952
thanks!
You can do either, standby or shut down. But once you shut down you need to manually turn it on.
You can also get one of the green power strips to power the external drive on and off.
I use one with my unRAID server to power my external drives on and off with the server since I use five multi bay port multiplier enclosures.
I use this one with my unRAID server since it is adjustable for the turn on/turn off wattage.
http://www.amazon.com/gp/product/B0006PUDQK
post #788 of 952
I have an HP EX490 WHS with a Mediasonic 4 bay enclosure and find that I will soon need to add another Mediasonic
The current Mediasonic is attached to the EX490 via the one and only eSATA port available - and iirc the SMART info and Addins like Disk Management only function correctly if the HDDs in the Mediasonic are connected via eSATA -- and if this is correct - will using an eSATA port multiplier to connect a 2nd Mediasonic encl. (and possibly more Mediasonics in the future) function properly --- or am I wrong about needing an eSATA port multiplier - and using the USB port(s) on the EX490 to connect the 2nd Mediasonic still allow for the SMART info and the Disk Management and other Addins to display the info correctly
post #789 of 952
You can only go from the existing eSATA port to a port multiplier enclosure. With a max of 5 drives. To add any more hard drives you have to use USB.
I have one, four bay, Media Sonic on my eSATA port, then six more Mediasonic, 4 bay, enclosures attached by USB.
I have three enclosures attached to a USB hub to the back, top USB port. Then I have three enclsoures attached to a USB hub on the front USB port. I also have three BD rom drives attached to a USB hub on the back, bottom USB port.
The front USB port is on a separate internal hub than the back USB ports which is why I split the enclosures up that way.
post #790 of 952
Thanks Aaron -- If I understand correctly - I can only have the 1st Mediasonic 4-bay enclosure attached to the HP EX490's one and only eSATA port - and if I wanted to use a 2nd Mediasonic 4-bay enclosure attached via eSATA through an eSATA port multiplier, the HP/WHS will only recognize 5 of the available 8 (eSATA att'd) bays/HDDs because WHS only supports 5 eSATA HDDs, whether they are attacheced separately, or attached via multibay enclosures... Correct?
And if this is correct and I have to use USB to attach any more that 5 HDDs... does the S.M.A.R.T. info and the Add-in info (ie... Disk Management and other Add-in(s) info) also give their intended information if used via USB instead of being used/attached via eSATA
post #791 of 952
I don't get the info from the Disk management add in from the USB enclosures. But I think the info partially showed up from the Smart Add IN. It would show the info from the first drive in each Mediasonic enclosure. Although I removed that add in later. At least I think that was the Add in.
As far a a port multiplier, I tried one before on the eSATa port. It was a 1x5 device. But I could only attach individual drives to it, not a port multiplier capable enclosure(It may have only seen the first drive, it's been a while since I tried it. I had hoped I would have been able to use multiple enclosures with it but it didn't work that way)
EDIT: The Disk management add in will show the status of each drive in my Mediasonics over USB as being healthy or unhealty but it doesn't show the temperature.
The SMART Add IN showed some info but if I remember correctly I think I had some issues with it. Maybe from the number of drives I have.
post #792 of 952
OK - Thanks Aaron -- what you are saying is what I seem to have found recently - at least I know the most important scenario is that multiple Mediasonic 4-bay boxes will work (via USB Connections), and allow BD ISOs (in your case) and (mostly BD MKVs and some BD ISOs in my case) to play without issue
Thanks again for the helpful info
post #793 of 952
Hi,
I am curious to know what you think of these Hitachi drives as they seem to be available at an attractive price of around USD 60 (for 2 TB), as an addition to my Mediasmart server. I still have my space on my current drives and have 1 free slot available to fill up. I am wondering if I should pull the trigger here or wait for better deals on this or other (may be 3 TB) drives in the future.
post #794 of 952
Hi,
The Hitachi 2Tb HDDs should be fine - I use them in Mediasonic 4-bay enclosures attached to my HP EX490/WHS
iirc 3Tb HDDs are not compatible with WHS v1 - plus the price per Gb is still higher than 2Tb drives
post #795 of 952
Hi,
I have 8 of them and no issues.
post #796 of 952
My HP EX490 Mediasmart has been in service over a year without any issues or problems. For the last two days or so it's been a little sluggish, especialy when trying to start and log onto the console. I RPD'ed into it, and had a quick look at things with Task Manager, but I didn't dare kill any processes through RDP without knowing the consequences.
I don't really know how to fully interpret what I see, but it feels like a virus...
The CPU usage is continually pegged at 100%, while the page file usage is low. THere are no applications running. There are only 8 processes running, of which 2 (taskmgr.exe and rdpclip.exe) are there because I invoked them, I presume. I have no idea if the other 6 are legit or not. One (wuauclt.exe) apparently can be a virus/trojan horse, but there is a legit app with that name as well. (The others are explorer, winlogin, csrss, WindowsSearch, and ctfmon, FWIW).
Threads and handles look reasonable, as do memory and kernel usage...
Clients still get files served OK; don't notice any change there.
I would appreciate suggestions on how to further diagnose this issue.
Mike
post #797 of 952
Mike
Do you have demigrator on? Any SMART issues with your Hard Drives? How much free space do you have on your O/S partition?
post #798 of 952
Hi Damian-
I haven't enabled demigrator myself, don't see it in either applications or processes as running. Is its executable demigrator.exe? Does it launch as a standard part of WHS? I see by research it is possible to add a bat file to kill demigrator, but I'm not sure it is running presently.
The frame has 2 identical 1 TB drives. All partitions in Disk Management show healthy status. Sys partition of drive 0 mapped as "C" has 10.92GB free of 20GB allocated. The other physical drive (1) shows a single 931GB allocation, with 505GB (54%) free. The data portion of physical drive (0) however shows a data partition 911.5GB allocation, of which 1000.44 is free, or 109%, whch looks odd to me, but I don't pretend to understand how disk duplication (which is on) reports this since all data space is mapped as "D". Is there another tool besides DIsk Management I should use to check for SMART errors?
Thanks for any advice,
Mike
post #799 of 952
Hi Damian-
Mike
Mike,
Do you have duplication enabled? If so then you do have demigrator running which has been known to slow down the systems at hourly intervals.
You have a good amount of free space on your O/S drive, my O/S partition ran very low on space which had brought my server to a hault at one point
Here is a good addin for monitoring SMART data in your WHS Console:
http://www.wegotserved.com/2010/01/2...-server-smart/
post #800 of 952
Yes, duplication is on. I burrowed down in Computer Management and see that it (and a bunch of other services) are running. I didn't quite get the difference between processes, as shown in Task Manager, and services, as found in Computer Management. At this point can I safely turn off duplication briefly from Console to see if the CPU usage drops? Or can I safely stop migration temporarily in Computer Management? I'm leery of doing anything VIA RDP other than looking at status, logs, etc. because of the full-page disclaimer/warning I see when I go into WHS by RDP.
Thanks for the link to a SMART tool; I'll attempt to check the two drives and see what's reported. Meantime CPU usage is still at 100%, CPU temp is 60C (usually 32-40C), and the last "storage balance" was 3 days ago, so I guess that's how long this has been grinding away. It's certainly not an hourly or intermittent process.
Thanks for your help; also reading your very thorough WHS blog looking for knowledge...
Mike
post #801 of 952
Mike
I would definitely schedule shutting off/on demigrator during the hours where it is causing issues (see my writeup here):
http://www.mediasmartserver.net/2010...s-home-server/
This is what I do, shuts off at 12pm and turns back on at 12am.
Let me know if you have any questions.
post #802 of 952
I guess I must be alone in how I use my WHS. I only use it for BD ISOs now so demigrator ony kicks in after I rip a new title
post #803 of 952
Demigrator kicks in afterwards as it rebalances frequently. Obviously the biggest impact may be right after a large copy, but demigrator runs periodically throughout the day
post #804 of 952
SMART add-in installed and working; was NOT fun since the CPU thinks it is very busy, and everything takes a LOOOOONG time to accomplish.
Anyway, both disks show zero bad sectors, zero pending bad sectors, zero reallocation events, and reasonable temps (38 and 39C respectively). All items in the details pane have green healthy checkmarks for both. I'm reading up on the meanings of the thresholds and values for my own edification, but presume if a status is healthy, that parameter is within norms.
Going back to Damian's original post, should I infer that demigration is hogging the CPU time? What is the safest way to, at least for a brief test, to stop duplication and see what happens?
Thanks again for yoiue help,
Mike
post #805 of 952
Mike
You would stop duplication by simply disabling it for each shared folder in your WHS Console. Keep in mind doing this is a hdd dies you are not protected
post #806 of 952
Yes. I mean the only time it will be transferring a large amount of data that will affect my streaming performance is after I rip a title. And that is only if the title I stream is coming from one of the two discs that Demigrator is reading and writing too. As long as it's not one of those discs I can stream one BD ISO without any issues.
post #807 of 952
I've read through much of this thread and this option for large amounts of data storage intrigues me. Although I'm reading that these have been discontinued, which makes me wonder why and if there's a newer model out there now I should be looking into. One thing that I like is the option to add on additional HD's beyond just the 4 internal bays (for instance going the mediasonic enclosure route) and have it add to the overall storage size. This allows you to continually add more storage as your needs increase.
My use will be mainly for dvd and bluray rips, but also a way to backup photos, home videos, etc. Is the mediasmart server (485, 495, etc) still a good option, or does HP have a more current model I should consider?
Going a bit off topic here, but what's to stop me from just getting a mediasonic 4 bay enclosure and attaching it by way of usb to my desktop PC? I suppose it wouldn't have the redundancy tied to it? Or I see there are enclosures that offer raid functionality. If I connect one of these to my PC would this allow me to have duplication of all data stored on it? Sorry, a bit off topic I know, but it's something I think about whenever I see these enclosures mentioned.
post #808 of 952
There is no reason why you couldn't just connect a USB enclosure to your PC. Really just personal preference. WHS v1 gives you protection right out of the box (duplication), you can easily add or remove a drive (something not so easy with RAID), your drives will be seen as one big pool, automatic pc backups, etc...
post #809 of 952
I've learned a lot. Thank you, Damian, for some good pointers.
I don't think disk migration was the problem, however. Here's what I found out:
I was in the process of turning off replication for each folder, one at a time. It was taking a LOOONG time, about 15 minutes PER FOLDER, because the CPU was slammed.
While I was waiting for console to finish changes to one folder, I idly RDP'ed into WHS again, opened Task Manager, and this time checked "show processes from all users". Suddenly I had a whole page full of things running, and on doing a sort by CPU usage, found TwonkyMedia at the top, using 99% of CPU time ! I hope I didn't break anything in WHS, but I forced the TwonkyMedia Tree process to stop inside Task Manager, and suddenly, the 490 came back to more normal life. I don't use Twonky, and have no use for it, so I may just disable it permanently once I'm sure nothing else is amiss.
Next, I'm going to restore folder duplication and watch things for awhile.
And now the $64 question is, why was TwonkyMedia running amok, and if I don't kill it permamently, what should I do to diagnose and prevent this from happening again?
Thanks all, especially Damian, for encouragement and advice.
Mike
post #810 of 952
Mike
Twonky is the default UPnP software that comes with the MSS. Most likely it is causing issues as it is constantly indexing your files. Unless you use UPnP I would recommend disabling
