@ Kei and others experimenting with the ION fix
I just did another channel scan to add ION back into the channel list. KKPX isn't causing the TViX to crash, but its PSIP is still not 100% correct. The TViX receives guide data from ION, but it will only show that data when 65-1 isn't tuned. If I tune to 65-1 and press the guide button, the guide says "No Channel" and acts as though I have no channels in my lineup; I can't even use the left and right arrows to look at guide data for other networks, because they are all missing from the guide.
If I tune to 65-2 (qubo) or 65-3 (ION Life) and press the guide button, not only do those channels display guide data, but 65-1 has guide data, too, and all of the other channels appear in the guide again. When I press the info button while I'm tuned to 65-1, it does show the name of the current and upcoming programs, but viewing the full guide doesn't work. I guess ION still has a few kinks to work out of the system.
*edit*
I checked again this evening, and the problem seems intermittent. I tuned to ION, pressed the guide button, and the guide behaved normally. I tuned to qubo, pressed the guide button, and the guide behaved normally. When I tuned back to ION and tried to open the guide again, I had to press the button at least three times to get a response, and when I did, I was back to "No Channel" in the guide again. I then turned back to qubo, got the guide back, went back to ION, and still had the guide. After that, I wasn't able to replicate the "No Channel" problem again. Perhaps it has something to do with the number of programs displayed in today's grid, as there are only two left in the guide for today. Has anyone else (near KKPX or elsewhere) experienced this?
Edited by Aleron Ives - 2/16/13 at 10:36pm
