Originally Posted by
Kei Clark
New beta 1.9.6b7 has been released, for those who are able to perform the upgrade via the TVIX, be sure to go to the beta firmware page (by pressing remote keys 2, 3, 8, 2, and "function"), or you can download it here:
http://demod.dvico.com/PreRelease/tv...0_1.9.6_B7.zip
I've only tested the OTA HDTV mode for the last hour so it's too early to comment. Below is the change log:
[Changes]
[ Multimedia Player/ System]
Supports MP3 album art
Supports image contained at ID3 tag
If an image exists on the folder where MP3 file resides, it will show as a album art.
Enhances Device Selection Pop-up window (This dialog will pop-up when you press GOTO button on file browser)
You can select variable USB devices, not as a fixed form
At device selection dialog-box, you can select device category by left and right button, you can select partition or USB devices by up and down button
Up-to 6 USB devices can be selectable.
Supports TERRET USB device
Up to 6 USB devices can be detected. (It was 2 devices before)
You can use USB2.0 to eSATA cable when you're using eSATA terret.
Supports Swedish and Greek language at setup.
Fixes cyclic rebooting problem after power off.
Fixes reverse ordered ID3 tag information problem.
Fixes MKV internal subtitle abnormal tinting problem
Fixes the aspect-ratio update problem of setup.
[PVR PART]
Supports recorded stream cut-editing function for transport stream
This function can be run at background ( You can still use DTV or file playback while editing function running)
Only supports .tp / .ts / .m2ts file extension
To use editing function
Press GOTO button to enter editing mode when playback transport stream file You can notice EDIT button enabled on the right-bottom side
Press Previous or VOL +/- remote button to MARK-IN or press Next or CH +/- to MARK-OUT, then select SAVE button on window.
The file will be saved as <<original_filename>>_tvix1.tp
For the detailed usage, please refer the below link:
http://www.tvix.co.kr/ENG/faq/defaul...rial=38&id=399
Fixes cyclic scheduled recording problem. (Sometimes, it's missing)
Fixes Czech's ETT information problem
[ Network/ UPnP]
Supports Wi-Fi 11n USB dongle based on Ralink RT3070 chipset.
(We only supports WPA setting at this moment)
[Known Issues]
[Limitations & Known issues of current firmware Rev 1.8.5]
[Player part]
[PVR part]
Dual recording will stop on ATSC if recording time is more than 2 hours each. (DVB-T is O.K.
