http://www.avermedia-usa.com/AVerTV/...il.aspx?Id=482
It looks like there is new and likely better option for 1080i video capture.
Description
The AVerTV HD DVR - is a High Definition / Analog video capture card. It's equipped with HDMI input and through the included Dongle Cable, users will have Component, S-Video and Composite Video input interfaces as well. This Allows users to connect to their Cable / Satellite Set-Top-Box, Gaming Console and HD Video recorders to capture High Definition and Analog video content on their PC.
The product information references Windows Media Center drivers and the site mentions that the AVer MediaCenter software can record from HD cable and satellite boxes.
Input Signal (HD)
Description
Input Signal (HD)
The only thing that seems to be missing is 5.1 audio and a validation from an actual HTPC user with a confirmation of the list of compatible HTPC software.HDMI
Component (YPbPr)
Stereo L/R Audio
