Originally Posted by Sean D.
I want the content to burned onto a stable, permanent, high-resolution removable media format (Blu-Ray), so I can eventually DELETE the original program content on my cable DVR box's hard drive. (and or desktop computer)
What else do I need to make perfect HD recorded copies of my favorite shows and sporting events off my cable DVR?
(for my personal video library)
(for my personal video library)Reliability of recordable BDs hasn't been proven yet, given they're only a few years old. 2TB hard drives look to be around half the cost of BD-R in $/GB, and don't require you to sit there (1) authoring to make a compatible encode and filesystem or (2) burning... Personally I don't see the point unless you really want to play them back on a standalone (that can't do USB playback) or lend copies to friends. Maybe someone else will step up to help you in this area.
Truly perfect isn't possible unless you can get the actual file off of your cable DVR (Firewire). The HDMI decompressed output can be captured and stored losslessly but clearly that isn't your goal.
You can probably get something visually close if you're careful. The biggest losses have already taken place on the cable encoding end. If you can't do firewire, install the card and try recording something off the box using the newest version of the software (1.7.8) to check whether it's HDCP protected. From there you can decide what app you want to capture with and whether to do encoding of the captured file.But yeah, none of this is gonna be "sit back and watch it do everything for you". The content owners don't want it that way.
You seem to say that you can choose the bitrate when you use aver media center to record. It takes a lot of disk space. Even with my aver hybrid, when i record HD OTA it's (only
