AVS › AVS Forum › Video Components › Home Theater Computers › AVerTV HD DVR: New PCIe HD Capture Card
AVerTV HD DVR: New PCIe HD Capture Card - Page 17
post #481 of 513
Originally Posted by LegionsGravity View Post
I need help PLEASE !!!!!!!!!!!!!!!!!!!!!!!!!!!!
I got the AverTV HD DVR and did any thing to fix the green bar lag. How can i fix it.mad.gifmad.gif
Select your correct signal video on Avermedia Center, options.
Claudio
post #482 of 513
AVer Media HD HVR
I set it to 720p and it showing this green lagging bars and when i set it to 480p it work perfect. Please i need help to set it to 720p.
post #483 of 513
Go to my youtube page and check what i'm talking about and if you can help me then thank you so much
my youtube page is youtube.com/LegionsGravity
and the name of the video is Aver Media HD DVR Green Lagg !!
post #484 of 513
I did bro. Check out my video on my youtube page, it named '' Aver Media HD DVR Green Lagg !!!
Youtube.com/LegionsGravity
post #485 of 513
First thing to try: put the card in a different PCIe slot on your motherboard if there is one available.
A user called leomarco had a similar problem which he solved doing this: http://www.avsforum.com/t/1196020/avertv-hd-dvr-new-pcie-hd-capture-card/360#post_21080918
By the way, could you tell us what your motherboard is and other system specs for future reference?
post #486 of 513
I don't know what is a motherboard but my computer is a Dell Optiplex 320
post #487 of 513
My preferred retailer has this card on sale for a (minor) reduction, so I'm trying to figure out if it would be a worthwhile purchase. I've skimmed this thread, but you'll have to forgive me for not taking the time to digest all 500 posts.
I want to use the card to capture footage from my PS3 in lossless (or with minimal quality loss) 720p over HDMI. Would someone be able to verify this is possible? From what I understand, I need to use VirtualDub and leave the card's software running in the background.
If that is doable, then the next concern is whether I have the necessary hardware to back it. I'm running a 3570k @ 4.2GHz and 8GB of RAM. I would rather not waste the write cycles, but I have an SSD which I can use if need be. Of course I would rather write to HDDs, but the speed (or lack thereof) may be an issue.
If any owners or aficionados could chime in, it would be much appreciated. Thank you!
post #488 of 513
Yes it is possible. For lossless, the write speed of the medium is the main concern. The denser the platter, the better.
post #489 of 513
My HDD is older, so its write speed is only 60MB/s, and 50 is probably the highest it would be stable. The SSD can do 150MB/s write.
What sort of speed would be required for 720p60 video?
(Presumably it would depend on which codec I use to compress it. With my processor, I would like to think I could use one which would provide decent compression.)
post #490 of 513
The video data for my 720p60 recordings is in the range of 32MB/s typically. It varies a few MB/s here and there. Give it a try. Do be sure to adjust the buffers in VirtualDub etc. with values like what a couple of us gave earlier in the thread.
My CPU is a Phenom II X4 965 and it mostly sits unused with Ut Video codec, but I don't think you'll find a codec that can do lossless at a better compression ratio in realtime on today's processors. Unless you want to drop to YV12 and use x264 lossless.
post #491 of 513
Hello guys,
I have a problem with Game Broadcaster HD. I am posting it here because this thread is alive.
I have a problem with recording from Intel HD 3000 graphics HDMI output. When I set the resolution of attached monitor (Game Broadcaster HD virtual monitor) to 720p and resolution 720p for recording video in MediaCenter 3D software, MediaCenter is upscaling it to 1080p and then shrinking back to 720p apparently. You can see it on video of static text which is not nice clean but most importantly when I make screenshot in MediaCenter it is 1080p image.
I am using Windows 7 64-bit on some Asus board with Core i7-2600K and I am capturing the ouput of the graphics on the same computer, but I guess it should not be reason for this problem.
Is it known problem or any idea?
post #492 of 513
I have the card set up and partially working. I accidentally installed the newest drivers which came with their media software. I went back and grabbed the older driver (thanks!) and now I can do the HDMI trick.
I'm having a problem with it, though. When I preview it in VirtualDub, it will drop frames even in the preview. It also does this in my recordings. There doesn't seem to be any rhyme or reason to when it drops the frames. More importantly, once it drops, it will stay low (anywhere from 30 to 5 fps) until I stop previewing in VirtualDub and start then start previewing again.
Is there a VirtualDub setting that I should be changing? This doesn't seem to happen if I preview with the bundled software or else I would inquire as to whether I should move the PCIe slot it is in.
I'm not sure if there is a solid answer for this, but thanks for all the help thus far.
post #493 of 513
I bought this card yesterday and will install it into a Dell XPS i7-3770 16GB DDR3 2TB 7200rpm with 256 SSD. I'm trying to pull some HD basketball games off of my Pace DVR (multi-room). I have used AverMedia's software in the past and it works fine for me, I guess. I experimented with FRAPS, VirtualDub and a whole host of other programs, but none of them could keep the frame dropping below AverMedia's software. My question is, with the OS on the SSD, would it be better to capture the MPEG files from component input to the 7200RPM drive, or the SSD? I'm guessing that the PC is more than capable of keeping up with the content, but which drive will have the faster/more reliable write speed.
These 6 games will each be in the 30GB range after completion, using the 30000 VQ at 29.97 1920x1080i Audio freq 48000 with 256kbs Audio encoding. In the end I have been using Sony Vegas Pro 11 to encode the final projects into a Blu-Ray image at 1920x1080 @ 60fps, 2 channel PCM. This is a brand new computer, purchased for this sole purpose. I imagine my prior captures dropped a considerable amount of frames, so I'm wanting to redo them with the least amount of frame dropping. Each recording lasts 2-2.5 hours, so the PC will get a workout here for the next day and a half.
post #494 of 513
Originally Posted by patrik2012 View Post
Hello guys,
Try Virtualdub or AmarecTV to recod this. AMC no have quality preview/record in MPEG2 mode. For any PC record using only AVI options.
In capture mode UNCHECK "Enable Audio Playback". If check, you will get low fps on recordings.
Mirillis Action! provide best capture then Aver Card. Its record full 1080p@60 with no slow game.
Why capture MPEG2 files?? Use AVI lossless capture with UT VIDEO CODEC (ULY2 mode). Its recor in max quality and no frames dropped.
Claudio
post #495 of 513
Hi Folks,
We are currently capturing under Win7 32bit with the .21 drivers and VirtualDub for capturing. The Capture HDD is a Raid o configuration with two disks
Our Signal is 720p50.
With the default settings from VirtualDub we are getting lost frames and plenty of inserted frames.
Within this thread I found some tips for the Disk I/O settings which we are trying now.
My question: Can someone post all related VirtualDub settings he/she is using in order to get no lost and inserted frames?
Thanks in advance, Sebastian
post #496 of 513
Originally Posted by bastiegger View Post
Hi Folks,
Do you try select NO PREVIEW mode in VD??
I have inserted frames if my source is 59.94 and select record to 60 (AMARECTV has this problem). But I select 59.94, no frames inserted problems.
Claudio
post #497 of 513
Hi everyone !
Since HDMI / HDCP seems to be unlocked with those special drivers, I would like to be able to capture the untouched transport stream coming from my STB (not a re-encoded version by Avermedia Media Center).
First of all, for the quality of the video, and second of all, because it would allow me to get 5.1 sound, which I cannot get using the provided software.
Can this be accomplished ? If yes, what kind of software do I need ? Hardware is not an issue here ... smile.gif
Frank
post #498 of 513
Originally Posted by citizenfish420 View Post
Hi everyone !
Frank
This is impossible. The TS is already decompressed by the time it gets to the HDMI port. You will need a CableCARD tuner, like the InfiniTV, to do this.
post #499 of 513
is it possible to get this device to record re-encoded video, but with 5.1 sound, like with the hauppauge hdpvr does with component cables ?
post #500 of 513
about InfiniTV, is there a chance a provider, such as Bell Fibe, can provide me such card ?
post #501 of 513
If you're talking about the InfiniTV, no, it does no encoding. IF you're talking about the HD DVR, I don't know
Is Bell Fiber a traditional cable operator (using coax inside your house, not IPTV)? If so, maybe. Unlike the US, Canadian cable operators are not legally required to offer CableCARD, but some do. You may also be able to take it out of a STB, as even without pairing you will get copy freely content, which is all you can use to do what you want anyway. Check your agreement with your operator for the legality of removing the CableCARD from your STB.
post #502 of 513
is it possible to get the AverTV HD DVR to record 5.1 sound, like with the hauppauge hdpvr does with component cables + sdpif ?
Anyone ?
post #503 of 513
No, the card only records stereo audio.
post #504 of 513
Thanks all for your help.
Sucky card overall. Hacked HDMI capture drivers are pointless without 5.1 sound. Returned the card for refund.
post #505 of 513
Hi guys,
Im new here so gentle please! ha. I happen to read a review on neweggs website for this card and a chap named tehminja1134sh said that it was possible to decode 5.1 audio over HDMI using the right capture program. Does anyone know anything about this? I have tried to contact him but no reply which is annoying. Here is what he said:
"A crapton of inputs, displays up to 1080i, and if you use the right program, will decode 5.1 surround sound over HDMI. Can record in insanely high quality with the right program and codec, and is overall an amazing card. Works wonderfully with my Wii via Component, my Xbox 360 via Component, and my PS3 with HDMI. Everything renders nicely in Sony Vegas, and looks great with the right settings."
Really would like to get this to work so if anyone ha even the slightest idea, i would appreciate it! I did try AmarecTV but that didnt show up 5.1 audio so at least that program is ruled out as the caputre software this guy used for surround sound.
Thanks in advance andd happy new year!
post #506 of 513
Hello, does anyone know where to find, or has a link to, AverTV MediaCenter 1.7.8? It is not available on the AverTV website (only 1.7.9 version is). I need the 1.7.8 for its ability to capture in AVI (for compatibility reasons). Any help would be awesome! Thank you!
post #507 of 513
Hi RomanSkl,
Sorry for delay in reply.
Get your file here:
AMCS 1.7.8 - 10061701
Claudio
post #508 of 513
Good Afternoon everyone ....
I have a card AVerMedia H727 used to use win7 64x driver AVerMedia H727 pcie tv tuner card 1.12.64.21 always used the program in Xsplit never had problems with HDCP ...
This week I had a malfunction on board tv, I had to arrange for warranty, I asked a colleague of mine loaned his plate like mine ..... There was a problem his plate AVerMedia H727 are not accepting the driver AVerMedia H727 pcie tv tuner 1.12.64.21 , ja ja did everything tested other driver, and still appears that black screen saying HDCP in the middle.
Usually the imagems error ..
In my old tv card H727 never appeared that due to having driver AVerMedia H727 pcie tv tuner 1.12.64.21 .... but this board should be newer driver not accept this smepre appears that this ......
I'm using this driver ...
here when this driver 1.12.64.21 installed tv card not recognized
I wonder if the way to get back to work Tues plate of Blocking it before Tiha HDCP ja ja have a plate equal about 1 year, always well accepted that driver AVerMedia H727 pcie tv tuner 1.12.64.21, never had problems with card always has to record and forward, now with this not accept ta ...
I can use the component quality is not anything like it on hdmi, I have to use the same hdmi input for better quality Recording
Use Teamviwer and accept help if possible so that the HDCP want out ....
PS: Plate AVerMedia H727 that I'm using now was bought this month, why not accept this not leave the driver install
respects
post #509 of 513
Thank you !!!
post #510 of 513
respects
Hi Tiago silva, try .22 version instead .21.
All H727 users report work suing .22 driver.
Try and reply
Claudio
