AVS › AVS Forum › Display Devices › Plasma Flat Panel Displays › Extend my plasma power cable question???
post #1 of 8
Hey guys, I have my Panny above my fireplace and the power cord is to short to reach my UPS.
Whats the best solution to extend the power cable? The stock panny has a very thick power cable btw.. I dont know if i could just cut the end off and splice into it with the same thickness of cable..
How about this from amazon..
http://www.amazon.com/exec/obidos/tg...X0DER&v=glance
post #2 of 8
Why not just use an extension cord?
post #3 of 8
I dont know.. That sounds simple enough but, I am trying to hide the wire behind one of those cable hiders and I dont think those ends will fit..
post #4 of 8
Also, I need to extend it by only 4 feet or so..
post #5 of 8
http://www.monoprice.com/products/se...rd=power+cable
they have basically any length you need as you just buy the length you need and eliminate the factory one. I definitely wouldn't splice it.
post #6 of 8
Yea, I was looking at those, but I dont think its thick enough..
post #7 of 8
My 54G10 came with an 18AWG cord. The Monoprice cables are available up to 14AWG. How thick do you want?
post #8 of 8
or just get a long enough extension cord that it stays inside the wire molding and make the connection between the two behind the TV.
