checked the stickies up top but the only relevant one was for avia and stuff
pretty quick question. Using Digital video Essentials HD, i had a question about the brightness pattern.
First, i believe the bars are +2%, +4% and -2% black right? with the inner bars being +2 +4 and the outer being -2. is that correct?
second, i wanted some clarification on where i should set the brightness. I see all 3 bars when i crank it. Where should i adjust the brightness? I dont think it should be to where the -2% (far right) bar just barely disappears, that seems a bit too bright. but i think its what the disk says to do. Should i just bump it up to where the inner bar is just barely visible? im not really sure what to do
right now i set it to where the far outer bar disappeared and knocked it down about 2 notches below that. that made the far inner bar about a notch or two above totally disappearing.
just wondering how this should be done properly, the description on the disk is kinda confusing
