By the ISO program, I'm assuming you mean the IP control setup program?
I will not pretend that I am well versed with that particular piece of software, I've avoided it like the plague.
I've said this before, I'm sure I'll say it again: I have N E V E R had a problem using the ISO-CATII box and a usb-to-serial adaptor - it's all I will use, because my connection has to work the first time, every time.
check the 'bay for an ISO-CAT II box weekly, they do pop up from time to time
Dan
BTW, you don't happen to have an old XP disc around at all do you? You might try loading a second OS to the machine- only to see if it works.
Dan
