I agree 96 kHz is the common rate for high end processors. The benefits of 96 kHz are compelling over 48 kHz, but 192 kHz, not so much. The new Datasat RS-20i runs at 192 kHz.Quote:
The BDP-93 manual states that it can output TrueHD 7.1 PCM at 192 kHz, so that implies it can do the same for PCM sources. But for DTS HDMA, 192 kHz is limited to 2-ch.Originally Posted by edorr
Good point. Someone posted on a forum the Oppo 93/95 only support 192/24 on 2 channel and downsamples 5.1 192/24, but the online Oppo specs are inconclusive.
to confirm 5.1 downsampling is not at work, you would have to play the 2 channel track on the 2L disc at 192/24 and see if this works with the ADA.
...... or may be not!
