Originally Posted by PabloReiter
Hi guys
just got a demo of the balanced version of the Rhapsody Mach iv. what a gorgeous yet simple piece of equipment. The only problem is that the box showed up from my dealer without ANY documentation or software. Can someone point me to a manual download and software download? I figured out a bunch already, but i cant get to the IP sections with just the on screen menus.
Thanks in advance!
Hi guys
Thanks in advance!
I would get your dealer to sort this out, I believe different firmware versions may only work with certain versions of the software. Also it is easy to screw things up if you don't know what you are doing.
You can download the Suite 7.1 HD manual here which covers most stuff but I would leave the IP stuff for the dealer, especially as it isn't your unit
http://www.livedigital.co.uk/2010/06...uite-7-1-hd/6/
Adam
