AVS › AVS Forum › Audio › DIY Speakers and Subs › Super THT build thread
post #1 of 243
Ok, so I am building a Tuba Home Theater subwoofer using the plans from Billfitzmaurice. I have maxmercy and myn to thank for their great advice and especially myn for his VERY detailed build thread! This build thread will not be anywhere near as detailed because I am working with my friend Joe who is a Professional woodworker with a degree in Furniture design = he is a woodworking genius! So since he is such a good wood worker, he works much faster than I would if I tried to do this build myself, so their will be very few brakes to actually sit back and take pictures.
I am building with Joe's help the THT 30" version because my wife is amazing and is letting me build one of the larger versions of this impressive subwoofer.
Here is a pic of the Dayton woofer I am using, it is the one that Bill recommends in the plans.
Here is Joe getting started on making cuts on his beautiful table saw, the magical tool that makes this build SOOOOOO much easier than with a circular saw!
Here is Joe doing the plunge cuts for the woofer access panel.
Here are all the major pieces minus bracing and deflectors
More to come in the coming week.
post #2 of 243
very cool.
post #3 of 243
Nice saw. Is that Baltic Birch? I am very happy with my Fitz Table Tuba, dual 8
" variety. The THT should rock.
post #4 of 243
It is Birch and is the best looking plywood I have ever seen!
post #5 of 243
As far as I'm concerned, void free plywood like this is the only way to go around here. My lungs won't stand for MDF dust, and the finished product ends up being lighter.
Looking forward to seeing how this one turns out too. I'm slowly getting to the point of deciding that if I want to learn horn design, I should start with building something already proven awesome and learn by doing. It also doesn't hurt that Solen carries the driver for us Canadians without having to deal with ordering PE stuff across the border.
post #6 of 243
Nice! 30" FTW!
That birch looks great. You going to finish it with stain or ?
Looking forward to watching this build. If I can be of any help, let me know.
post #7 of 243
He'd get a far more accurate and straight cut by using a guideboard or saw sled. It would be safer too. Fingers and saw blades are a bad combination.
post #8 of 243
Sweet! But what's the freaky-looking thing in the corner?
post #9 of 243
its a cat
post #10 of 243
I don't tell Joe what to do, he's the master wood worker. Cuts turned out great. Thanks for the heads up though.
post #11 of 243
He's my sphynx cat.
post #12 of 243
hehe. Cats LOVE horn's. I'll let MaxMercy tell his story about his cats and what he did to keep them out of the throat of the horn .
post #13 of 243
If that saw catches it will not run toward his hand. It is a worm-drive saw. The blade turns the opposite direction from a regular skil-saw. Nice strong saw, but they are heavy.
post #14 of 243
Regardless, Bill's right. Those plunge cuts need to be as straight as possible and a guide board would guarantee the straight cut. Keep in mind that the access panel cover is cut out and used from those 4 cuts as well as the opening for the driver from the side panel. Very very important cuts .
post #15 of 243
Not arguing that at all. All I was pointing out was his fingers toward the front of that saw are not in danger. That saw will kick back not forward. I doubt that many here are familiar with a worm-drive.
post #16 of 243
I fail to see why they have to be as straight as possible, in my understanding the seal is actually made with the trim pieces that the access panel actually sits down on to. We are actually making a panel to exact dimensions as the hole, not using the wood that was cut out when making the access hole. We are designing fake door panels to go over the access panel, we are making this THT into a piece of furniture that will look like an end table... a very big end table.
post #17 of 243
The access panel flanges sit flush against the interior panels 1, 2 ,3 and 4. As long as those 4 panels are flush against the edges of the access hole the flanges should be golden. If though the access hole is cut sloppy there may be some over/under hang. Sorry I should have explained it better.
This may explain it better:
MaxMercy stained his THT. It turned out really well. Are you going to add any additional flare to the outside of the THT to make it look an end table?
post #18 of 243
I see what you mean, I will make sure that things are within the tight tolerances. The plan so far is to add crown molding along the top and bottom edge, use granite tile for the top, make fake doors and a drawer to cover the access panel (but still be removable) with brushed stainless steel handles and paint the whole THT a dark charcoal gray. I will draw up a sketch of what I want it to look like and post it.
post #19 of 243
WAF +10. Very cool
post #20 of 243
This looks like a cool build off to a good start!
But that cat reminds me of Pet Cemetary.
post #21 of 243
I received my speaker terminals in the mail for about 6 bucks shipped! Gonna get back to work on the build in the next couple of evenings.
post #22 of 243
Originally Posted by Rightbrained View Post
its a cat
that is an awesome lookin sphynx!
post #23 of 243
Thanks, that's very nice of you to say! I have three sphynx cats, they are the most personable cat breed you can find because from a very young age they learn that they have to come to humans for warmth!
post #24 of 243
are they rather spendy? how well "trained" rather domesticated? I'll be moving into my own home soon, so no more "no pets!" and that cat is beautiful!
just to stay "on topic" more pics! I know, you've got a builder and not much time to snap away, just had to say it
post #25 of 243
Nice to see another horn build! I have a worm drive saw, but didn't realize they turned the opposite way. At any rate they are heavy, but it's nice to be able to see what you're cutting without having to lean over the saw.
post #26 of 243
SO I am debating on what amplifier to get now, was sold on the Oaudio 500 watt, but now with everyone saying how efficient this subwoofer is should I just go ahead and get the Oaudio 300 watt version?
post #27 of 243
It's unlikely you'll ever use more than 100 watts. 300 would have plenty of headroom.
post #28 of 243
Here is a pic of the start of the horn being built, I am so glad that Joe is helping me out with this build, he is a woodworker, I am definitely not!
post #29 of 243
Not really that great of a pic, but here it is anyways.
post #30 of 243
Here is a picture of a dork next to the project (me) to give scale, this thing is HUGE!!! (that's what she said)
